c2050 copies with no gray in B&W - prints ok!
Re: c2050 copies with no gray in B&W - prints ok!
did you check that lever that locks the black drum and brings the ITB closer to drum?
I had this and it gave me an undertoned copy/print.
It would lock over but it didnt go correctly. took it apart and played with itComment
If the calibrations ACC printout sheets looks normal, i would also check user tools - > scanner and copy/document server settings. Check and set the parameters to default. Do a scan with a color/bw test chart to the document server and have a look to the preview if it's ok or not.Comment
