Ricoh MP C2051 Quality problem
  • Ales
    • Oct 2013
    • 14
    Hello to everyone,
    I have problem with ricoh MP C2051,printing half sheet ok and the other half with light color.
    I replace PCDU Color, transfert belt unit complete, laser unit but not result! Any idea ?? ThanksColor test pattern.jpg
  • copier tech
    • 8164
    Re: Ricoh MP C2051 Quality problem
    Check the 2nd transfer roller looks like its either not located at one end or broken etc.
    โ€‹
    • fshead
      • 2376
      Originally posted by Ales
      Hello to everyone,
      I replace PCDU Color, transfert belt unit complete, laser unit but not result! Any idea ?? Thanks[ATTACH=CONFIG]40066[/ATTACH]
      is this copy lettrer "r"
      or regular letter?
      i dont if you have a trail edge being lite or a side lite.
      • fshead
        • 2376
        i would look at the transfer roller springs and mechanics on the right side door.
        It is easily swapped out
        • 8T2
          • Aug 2015
          • 257
          Agreed one of the levers probably broken on transfer unit and not locking in place on both sides
          Sent from my ALE-L02 using Tapatalk
          • Ales
            • Oct 2013
            • 14
            Thank you for everyone's help.The lever set rear on the transfer unit it is damaged and the tension of the spring was not the same.
