Ricoh Mpc4500
  • Users Tech
    • Nov 2013
    • 85
    Ricoh Mpc4500
    Hi to all,
    i printed a colored book using Ricoh mpc4500 and the black text is not solid black. it is a little blurry for the black text has color on it. I changed some settings in the printer driver setup but no change. There is not much to change in the printer driver settings, i am thinking maybe it's the settings in the machine that i need to change. if i print black only with no color, the black print is perfect. what settings do i need to change? Any help please.
  • copier tech
    • 8138
    Re: Ricoh Mpc4500
    Originally posted by Users Tech
    Hi to all,
    Post some print samples
    • DDlan
      • Mar 2017
      • 26
      Re: Ricoh Mpc4500
      i don't understand what do u print
      • UNICORNico
        • May 2018
        • 308
        Re: Ricoh Mpc4500
        What the partner wants to say is that you make captures of the printing defect and attach them to the post so that we can see, said impression anomaly.
        A cordial greeting.
        "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
        • daveh12
          • Jul 2012
          • 157
          Re: Ricoh Mpc4500
          Images would definitely help here
          • blazebusiness
            SanDiegoCopierRepair.com
            • 1250
            Re: Ricoh Mpc4500
            Hi to all,
            Symptom 1 black prints not solid-----Try the ACC adjustment to see if blacks improve. (user tools/maint/auto color calibration)
            Symptom 2 Blurry copies---- color registration may be off. If you are a tech , clean the ID sensors , then just go into SP mode and run the forced line adjustment to see if that fixes the issue.
            1. First do SP2-111-3.
            2. Then do SP2-111-1.
            If you are not a tech , you might want to call one if the ACC adjustment in user tools doesn't help.
            He can quickly clean the ID sensors and run that line adj in SP mode.
            • Users Tech
              • Nov 2013
              • 85
              Re: Ricoh Mpc4500
              attached printouts from Ricoh Mpc4500 and Hp cp4525 using the same document. as you can see in the pics the black prints using Ricoh is not as clear as Hp printouts. With Hp there is an option in the printer settings to set it as auto or manual setting and i set it at manual. Also, on the Hp printer i can select from 3 options: 1.) auto, 2.) mostly color, 3.) mostly black(i can save toner on this for it will only use black toner on black text)
              Please help.
              • ridgemill
                • Sep 2017
                • 189
                Re: Ricoh Mpc4500
                The text is being processed as an image, if you print the same document as B&W, the text should be a lot clearer.
                You can try changing the Print Quality settings in the printer driver preferences / properties.
                However, this model is limited due to its age.
                • AjitN
                  • Mar 2009
                  • 287
                  Re: Ricoh Mpc4500
                  Please help.
                  Please try to understand the difference in machine design(even if I am not able to clearly prove technically)
                  There is difference in toner in HP & Ricoh.
                  I presume by look of prints, you are talking/comparing HP black & white machine(pls correct if I am wrong, if so then it could be some different solution) with Ricoh color machine.
                  Color machines (Any brand which uses powder toner) use translucent toner ( Which is semi-transparent and four layers put on each another and after fixing, it develops different shades)
                  B & W toner is OPEC which do not allow light to pass through it, SO LOOKS MORE DARKER.
                  This can be easily viewed if you print BLUE(Magenta+Cyan) patch on Yellow shaded paper, which turns out to be more darker(blackish) than printed same on white paper.
                  Hope this helps to make customer understand the difference.
                  • copier tech
                    • 8138
                    Re: Ricoh Mpc4500
                    These are two totally different machines, you will NEVER get them both printing as the exact same quality.
                    The MPC4500 is such an old machine could have a number of parts worn out.
                    If you customer is this fussy its time they upgraded!
                    • Users Tech
                      • Nov 2013
                      • 85
                      Re: Ricoh Mpc4500
                      the machines that we used in printing the sample prints in the attachments are both color machines. I am wondering why Ricoh is printing the black text as image.
                        • 37449
                        Re: Ricoh Mpc4500
                        If it is printing it as an image, it is because the computer is sending it as an image. If you want us to analyze color print quality of the C4500 for you then send us a sample printout of something that we are used to analyzing such as Printer SP 1103-2 color pattern test print.
