SP C830DN Fuser
  • ABS tect
    • Sep 2013
    • 511
    SP C830DN Fuser
    Anyone know if i can use the fusing sleeve and/or pressure rollers from a 3502 or 4502 fuser for this fuser in the sp c830?? They look very similar but wasn't sure as far as heat output and other things not quite lining up right
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: SP C830DN Fuser
    Already discussed in great detail in a previous post see link below
    http://www.copytechnet.com/forums/ri...ht=#post632476
    The fuser lamps are different in the C3502 and C4502. You can use the C4502 and C5502 fusers in the SP C830dn. Due to differences C3502/C3002 fuser may have compatibility issues and not last long.
    • ABS tect
      • Sep 2013
      • 511
      Re: SP C830DN Fuser
      I appreciate it greatly...put a 4502 fusing sleeve on it that we had in stock and the customer is back up and printing in less than 48 hours! Thanks!
      • blazebusiness
        • 1250
        Re: SP C830DN Fuser
        Glad to help......lots of great tech's assisting each other on this site. Always impressed with the solid Ricoh advice from Oze,slimslob,copier tech,sturmtrooper,phil b,tonermunkeh and so many others.Just no way to mention all of them.
        Special mention to slimslob with over 8,000 posts. Wow, dude, really? Do you ever sleep? Amazing commitment to sharpening your skills by helping others. Blackcat 4866 is the top poster on the forum with over 16,000 posts and is great on multiple brands............For Canon copier advice Teckat is the bomb and has over 15,000 posts. But don't think anyone beats slimslob on the sheer quantity of Ricoh posts.
