Ricoh MP C4503 C5503 C6003 wax lubricant bar
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Was at the wholesaler and another tech mentioned to me that there was a Ricoh bulletin on the importance of removing a spring for the wax lubricant bar when installing a PCU. If you don't , it can cause early wear / lines in the drum surface.
    Signed on to TSRC but couldn't find that info under Service bulletins. Does anyone have a copy of that info?
    He also mentioned a fix for tray one jams by using a gear from the c2503 instead of the gear in the C4503/5503 but I doubt there is a bulletin on that.....sounds like he came up with his own fix for tray 1 jams.
    Your feedback appreciated.
  • totoro
    • 568
    Re: Ricoh MP C4503 C5503 C6003 wax lubricant bar
    I think the other tech was referring to the attached file when replacing a pcdu. It's in the service manual. I don't know about the tray 1 gear. pcdu replacement.pdf
    Totoro
    • blazebusiness
      • 1250
      Originally posted by totoro
      I think the other tech was referring to the attached file when replacing a pcdu. It's in the service manual. I don't know about the tray 1 gear. [ATTACH]40124[/ATTACH]
      Thanks for responding.............I saw that in the service manual also. Instructions for releasing the spring pressure for the C5503 (D149) and C6003 (D150) only. It seems like he was referring to some other procedure or bulletin though. But you may be right. If you are correct......interesting that it doesn't say to do this to the C4503's
      • copier tech
        • 8107
        You get instructions in the box with every new PCU, inexperienced engineers simply fit the drum without checking this sheet thus drum wears out prematurely.
        Metis series has an excellent pickup/feed system so I would not try & improve something thst works!
        Howver I do fit the AF030094/1094/2094 rollers to the Metis MPC2xxx series, more expensive but the life is 10 fold.
        • blazebusiness
          • 1250
          Yes, that sounds like what he was referring to. You release the lubricant bar tension by removing a spring. Location---------is it at the rear of the pcu?
          • copier tech
            • 8107
            The spring is located in the central area of the PCU. Again instructions are provided with each new drum unit so you cant go wrong!
            • blazebusiness
              • 1250
              Got it............So Totoro must be correct. It has to be the illustration he provided from the service manual. And a installation sheet included with each PCU also shows the info. Thanks again to both of you.
              • Tatteous
                • May 2017
                • 24
                You don't actually remove the spring. You lessen the tension. Only on the 55 and 60 speed machines.
                • copier tech
                  • 8107
                  This is an important step it really does shorten the life of the PCU & given the cost of them for a 5 second spring hook release!
                  • FrohnB
                    • Jul 2017
                    • 1919
                    Even on the slower speed Machines we move the springs. Ridiculous not to. 1/10th of its "expected" yield (270k) if you don't.
                    Omertà
                    • fshead
                      • 2356
                      HI
                      I read this and deal wth c3003 and c3503 series.
                      Are you saying the drum will wear out at " 1/10th of its "expected" yield (270k)"
                      27k copies or the lub bar?
                      I have not had issues but dont want any either.
                      MOst of my machines are under 100k.
                      thanks
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        But in that case perhaps noise can be an issue?
                        • fshead
                          • 2356
                          I am one who tries to stay ahead of possible headaches.
                          Have not had any loud drum noises yet..
                          I have not rebuilt any mpc3003 drum units "yet"..
                          But I guess I will pull apart one will time allows me.
                          Are you guys getting the expected yield of these drum units?
                          thanks
                          • FrohnB
                            • Jul 2017
                            • 1919
                            Originally posted by fshead
                            HI
                            thanks
                            It states in the PSG or Service Manual that if you don't adjust the springs for the lube bar, then the PCU's expected yield will be 1/10th of what's stated. In the 3003 3503 models, the manual will tell you NOT to adjust the springs, we ignore this and do it anyway, it says that "this procedure is only for the 55 and 60 models. Have not had any problems with noise or anything like that, just longer lasting drums! Usually past the 270k stated.
                            Omertà
                            • FrohnB
                              • Jul 2017
                              • 1919
                              Have never had a noise issue by doing this.
                              Omertà
