mp c4503 with e 22c fiery
  • jtymabel
    • Aug 2008
    • 164
    Trying to install a fiery on a mp c4503 (sp 5193 set to 1) . the fiery tower is labeled e 22c but when i connect it to the copier it shows functional problem.
    i can log into the fiery from a pc and i was able to connect to it via command workstation. i noticed that on the command workstation in labeled as a E 22B. I have the system software for the 22b/c. Can a fiery e 22b be changed to a e 22c.?
    thanks
  • davel
    • Oct 2011
    • 1104
    Re: mp c4503 with e 22c fiery
    Why would you want to put a fiery on a office machine? Are you using gigabit nib.
    • jtymabel
      • Aug 2008
      • 164
      Color output is better (color matching). Customer wanta better output.
      Gigabit nib is only for mpc3003 and 3503.
        • 37495
        Gigabit connection is required for ALL Fiery. Since you don't even know that, you should not be anywhere near a fiery.
        Color controller connection type M3 is for the mpc3003 and 3503 only. For the MP C4503/C5503/6000 requires type M4.
        • jtymabel
          • Aug 2008
          • 164
          Using the the gigabit ethernet m4. I thought the last post was refering to the m3 (the one that can be installed without opening up the board)
          • skinnyb
            • 291
            I had one that did wierd things similar, might verify firmware on the machine. I know there is a firmware compatibility chart on the tsrc regarding fiery compatible firmware. General rule of thumb for me is to being all up to date and go from there. What version OS is on the fiery? I believe the original was 1.0 but I ordered DVD to reload one a while back and they sent me 1.1. Maybe if you can get into via CWS, see what patches are on the fiery as well.
            Me personally, I can't stand fiery on this machine.. Way overkill for a business color machine. The embedded system is more than sufficient for anything this engine is designed to do. If your customer is that demanding on color quality this isn't the right machine IMHO.
            Sent from my VS987 using Tapatalk
            • jtymabel
              • Aug 2008
              • 164
              Software ver 1.10 patches and firmware all up to date. Customer currently has a mpc5502 with a fiery (movie production). they love it. They need another one for 1 month.
              • skinnyb
                • 291
                Question? There are 2 programs that have to be flipped in service mode on the machine. Did you flip them both? One is external print controller on and the other is application in validation for the embedded printer. You have to invalidate the embedded printer with 1 and validate the fiery with the other. If you don't do both, it will error out...
                The 4 modes to change from the SM are:
                SP5193-001 to 1
                SP5895-001 to 1
                SP4201-003 from 11 to 15
                SP4201-004 from 11 to 15
                Hope this helps.
                • jtymabel
                  • Aug 2008
                  • 164
                  [QUOTE=skinnyb;668747]Question? There are 2 programs that have to be flipped in service mode on the machine. Did you flip them both? One is external print controller on and the other is application in validation for the embedded printer. You have to invalidate the embedded printer with 1 and validate the fiery with the other. If you don't do both, it will error out...
                  SP5193-001 to 1
                  SP5895-001 to 1
                  yes. except for sp5895. (didnt want to disable gw scanning)
                    • 37495
                    GW scanning can be done as long as you disable Fiery Scanning. See this post from more details. you will need 2 network connections. 1 for the fiery and 1 for the MFP.
                    http://www.copytechnet.com/forums/ri...28=#post592120
                    • skinnyb
                      • 291
                      [QUOTE=jtymabel;669981]
                      SP5193-001 to 1
                      SP5895-001 to 1
                      There are 2 under 5895. 5895-01 is printer invalidation and 5895-02 is scanner. Just flip 01 to a 1 and leave 02 alone and gw scanning will still work fine. You have to disable embedded printing and enable fiery printing both in order for fiery to work.
                      • jtymabel
                        • Aug 2008
                        • 164
                        [QUOTE=skinnyb;670051]
                        Thanks for the replies...I think the issue is that the e22b fiery only works with mpc6502/8002/ proc5100. The one i have is a e22c, but when i check in command workstation is shows as a e22b.
                        • fshead
                          • 2376
                          I cant talk for this guy but on my account i buy lease returns and resell them and if happen upon a fiery and a customer wants it why would
                          prevent myself from making a few extra dollars..
                          Now if its going to be a total headache then ill pass but sometimes a customer who wants to be the "kool kid at school" with the latest
                          gadget..
                          • jtymabel
                            • Aug 2008
                            • 164
                            gadget..
                            I rather not deal with the fiery, but i have to. This particular customer is asking for it. You are right. For a couple of dollars is not worth it, but they rent machines year around and its more than just 1 copier. Basically I'm pampering this customer.
                            • jtymabel
                              • Aug 2008
                              • 164
                              Update. Found this in an old TSB.
                              "Refer to the above compatibility table, if you plan to pre-install and pre-configure the E-22C before customersite installation, or if the copier model in use with the E-22C is to be changed.For example, if the copier in use by the customer is C5503, E-22C needs to be pre-installed and preconfiguredwith C5503 or C6003 or C4503."
                              Maybe the fiery was initially installed on a ProC5100 and it was configured as a E22b.
                              Also checked all the part numbers for both e22b and e22c and they are identical.
