compatible
  • stobby2
    • Oct 2013
    • 137
    compatible
    Hi Guys.
    Quick question. Is the controller/netwrok pcb assembly for the Ricoh MPC2500 B2315782. compatible with the MPC3000. Everything else seems to be. Cannot find a definitive answer anywhere
    Cheers
  • Zeldaman
    • Mar 2011
    • 946
    Re: compatible
    Hi there!
    No, they use different controller. My last information: MPC 2500 = B2315781 MPC 3000 = B2385781
    Hope this helps.
    Greetings...
    • stobby2
      • Oct 2013
      • 137
      Re: compatible
      Originally posted by Zeldaman
      Hi there!
      Hope this helps.
      Greetings...
      Thanks 4 that. Shame as we have a good 3000 and a hashed 2500. Thanks Again
      • fshead
        • 2356
        Re: compatible
        i still see a used one show up now and again.
        you might find someone willing to part one out cheaply for you.
        • sturmtrooper
          Copier Combobulator
          • May 2016
          • 587
          Re: compatible
          Originally posted by stobby2
          Hi Guys.
          Cheers
          Controller boards are ALWAYS machine model specific. This is also the board that tells the machine which machine it is so you can see why they would not be interchangeable.
          • stobby2
            • Oct 2013
            • 137
            Re: compatible
            Thanks for your help guys. Always worth a go just in case someone has found a way around it. I do not deal that much with Ricoh but l have managed to sort this issue with various Canon Machines.
            Have a great day
