SOP panels interchangeability and models
  • fshead
    • 2356
    hi
    I only started selling used units with SOP panels,ie mpc3003 and mpc401sr .
    Did it start on these model in the color segment?
    Was wondering if it was an option on mpc3002.
    And can you swap panel from different machines?
    thanks
  • copier tech
    • 7931
    Re: SOP panels interchangeability and models
    No the MPCxx02 series never had that SOP option.
    The panels are interchangeable, check the part numbers.
    • fshead
      • 2356
      thanks
      off hand do you think the mpc401 will swap in a mpc3003?
      i have a pending order but need 12 by 18 and would have to get a mpc3003
      and try to swap panel
      • sturmtrooper
        Copier Combobulator
        • May 2016
        • 589
        Originally posted by fshead
        thanks
        The MPC401 takes smart op panel type m10 product code D190. The C3003 takes smart op panel type M3 product code D148-81. So I doubt they are interchangeable. Even if they physically are interchangeable the firmware may not work.
        • fshead
          • 2356
          thanks
          I have a mpc401 wth SOP in stock and sold a mpc3003 to an account who has a buddy who wants the same set up.
          I was hoping but wont play frankenstein with these machines.
          • guitar9199
            • Sep 2016
            • 1097
            thanks
            There is a VERY specific procedure for converting the Normal op panel on the MP CXX03 series to a Smart Op panel. Make sure you follow it correctly.
            The operating system update procedures for the SOP are ALSO very specific.
            • Polarbear
              • Feb 2012
              • 1070
              Hi
              All The Android panels are the same, except for the brackets and possibly back covers.
              As far as changing a normal panel to Android, I agree with the previous poster, as there are settings that have to be done to tell the machine that it now has an android panel and not the standard panel.
              Press the GREEN button!!
              • fshead
                • 2356
                HI
                Thanks.
                I never did a swap over from NOP to SOP.
                I did see you need to do FW "SOP"version.
                Do you swap panel 1st and then flash FW UPON 1 ST REBOOT?
                • FrohnB
                  • Jul 2017
                  • 1919
                  I believe you have to update the SOP system firmware 1st and then the SOP Engine firmware (with NOP still on) and then the rest of them (SOP versions). Then there are a couple SP modes you need to change (if I remember correctly)5748-101 and 201, turn machine off, swap the NOP for the SOP, turn back on, and then go back into SP mode and change SP 5752-001 and 1041-001 (I think those were it) . Hope this helps.
                  Omertà
                  • fshead
                    • 2356
                    THANKS..
                    I like it much better when i go to pick up my machines and to my surprise i find it has the sop panel..
                    But I guess I can handle changing a c3003 to SOP c3003.
                    I have a good window wth this pending order and many other things to do.
                    • fshead
                      • 2356
                      Originally posted by Polarbear
                      Hi
                      thanks.
                      I am curious if you "or anyone else seeing this" have ever swapped a mpc401 SOP panel in a different model"ie here a mpc3003".
                      I always worry about wiping out a controller by not having all the questions covered.
                      thanks.
                      • Polarbear
                        • Feb 2012
                        • 1070
                        thanks.
                        thanks.
                        We recently fitted an mp402 panel to a mp6002 to test if the 6002 panel was faulty (which we confirmed) as the 402 panel started right up and the original 6002 panel just shone a blue power light....
                        Sent from my SM-G950F using Tapatalk
                        • fshead
                          • 2356
                          hi
                          thanks
                          these were both SOP and did you have to preload the correct FW b4 running it 1st time?
                          • Polarbear
                            • Feb 2012
                            • 1070
                            hi
                            thanks
                            Both were SOP. no it was plug and play. No firmware issues.
                            • fshead
                              • 2356
                              thanks much
                              I still have a lot to learn with these SOP panels.
