Ricoh AF 2238C Scan to email problems
  • ricohtek
    • 17
    #16
    SSL
    Like I said on my other post Ricoh machines DO NOT support SSL(STARTTLS). I used telnet to connect to smtp.gmail.com on port 587 and I got a message telling me that I must use STARTTLS. You can create a free email account with AOL and send email through that.
    • dv007833
      • Aug 2008
      • 43
      #17
      Problem solved!!!
      Hey everyone,
      Thanks for all the help and input. Finally works. Ended up using the ISP provided email address, switched of authentication and voila, it started working.
      So i guess any external webmail using SSL will not work with Ricoh machines. Lesson learnt after a painful few days.
      • Star
        Ricoh Tech
        • 127
        #18
        Originally posted by mmru4real
        Guys Gmail actually uses port 587 for smtp, I have setup 5 to 10 of these and it works like a charm, just make sure smtp authentifcation is turned on.
        I'd be interested to know in detail how you are accomplishing this, as it is VERY true that Ricoh's machines do not support SMTP with SSL. I've tried every possible combination trying to work around this with no luck.
        Regards
        • pixelatedsound
          #19
          Google's website says SMTP is available on Port 465 or 587, so you might try both.
          • Star
            Ricoh Tech
            • 127
            #20
            Yep, Have tried both. As well as the other suggestions you recommended to no avail. (Lucky for me, I have a machine in my shop that I have been messing with along with a gmail account I set up.)
            Haven't quite given up yet, but getting close, lol!
            • dv007833
              • Aug 2008
              • 43
              #21
              I tried using a gmail address but never worked. So best solution is use and ISP that doesnt use SSL, i think someone suggested AOL. Or in my case im using the email address that the company was assigned when they signed up with their ISP.
              Hope this helps..
              • roosterfish
                #22
                Originally posted by dv007833
                Hey everyone,
                Do you mean that you used the ISP provided e-mail to log onto g-mail? I know that doesn't make sense, but it seems to be what you referenced.
                I just had ATT come in and screw up my customers ability to scan to e-mail because of the SSL requirement. I'm trying to get around it and would like to use g-mail if possible. I don't have many opportunities to play with the machine as my company has given up and won't authorize me to go out without charging them, which I hate.
                • dv007833
                  • Aug 2008
                  • 43
                  #23
                  You have use the ISP provided email address which hopefully in your case doesnt use SSL. You cant access gmail because it uses SSL which the AF 2228/32/38 dont support.
                  From what i've learnt it is not possible to configure the machine for scan to email using Gmail.
                  • brouwer
                    #24
                    SSL certificate 1
                    Hello,
                    how do i get the SSL certificate?
                    • Fearless V K
                      • 620
                      #25
                      Unless the customer has an internal email server, we always use the ISP provided email account and password, or the email will not authenticate. That is whatever account (username/password) the customer would use to log into their ISP account to get their email on the web. It also helps eliminate DNS issues if you use the IP address for the SMTP server instead of the name.
                      Don't take that toner with me!
                      • apache_cat
                        I.T. Tech
                        • Jul 2009
                        • 81
                        #26
                        Just read through this thread. Thought I might add this solution.
                        Had a problem with a customer trying to use scan to email from ricoh using gmail. Intermittently working. Customer I.T. blaming photocopier of course.
                        Having read another thread here some time ago that suggested using gawab.com when you need an smtp server. I can verify that this works and is very handy to prove to an I.T. twat that there is nothing wrong with photocopier.
                        Just go to www.gawab.com set up an account. Use psmtp.gawab.com as smtp server. Turn authentication on and use user name and password that you used to set up email address. Port 25 or 587.
                        Thanks to original thread that provided this alternative.
                        • jackiecck
                          • Nov 2009
                          • 16
                          #27
                          I setup my email account that provided by the ISP to the machine and then scan to email to another email account from the same ISP, it goes through successfully; but when I scan to a gmail or hotmail account, it failed. Is it because of both of them also got SSL so the email can't go through?
                          • Jomama46
                            • 2900
                            #28
                            More likely that neither use an smtp
                            sigpic
                            A+; Network +; PDI+
                            • Lderib
                              #29
                              Help, please: cant't set scan2mail with gawab on Ricoh aficio SP C232SF
                              Hello all,
                              I've just followed the instructions in order to use a free gawab account but it does not work. Always "connect to server fail" immediate error.
                              My settings are: (see printscreen)
                              smtp.gawab.com
                              port 25 (also tried 587)
                              SMTP authentication
                              myusername@gawab.com (also tried without the @gawab.com)
                              password (of course ;-))
                              But nothing works! It drives me crazy.
                              Can someone help? What are the other network settings? DNS? DHCP?
                              Best regards,
                              Luc
                              • TonerMunkeh
                                Professional Moron
                                • 3865
                                #30
                                Open a DOS prompt and ping the smtp address. Try the IP address it gives you and see if that works.
                                Hit it.
