Gears in the devlopment unit
  • sandmanmac
    • 3973
    Re: Gears in the devlopment unit
    It's usually the conductive bearing at the rear that seize up. There was a thread a couple o years ago that gave the part # for the bearing and a link to a video on how to remove it.
    Agreed, but I've personally seen both.
    In fact, I had one with the gears chewed up just a couple of weeks ago.
    • fshead
      • 2356
      On a more elemental level, the developer is agitated to produce the tribo-electric effect, which is essentially static electricity, which attracts the toner particles spherically around each particle of ferrite.
      Without agitation there is no tribo-electric effect. The toner does not statically cling to the ferrite particles and just sits in the bottom of the developing unit. The toner sensor identifies low toner density and dumps loads of toner into the developing unit. If this continues for any length of time the developing unit will fill until toner is bursting from the seams of the unit, or the machine indicates low toner, or both. =^..^=
      "tribo-electric"
      i have not heard that phrase in 25 years maybe more ...
      Makes me think back on old analog b/w sharp or minolta copiers where you
      would adjust the dev unit after installing new developer using a allen key sensor that
      you would turn till both leds would flicker................its come a long way
        • 22973
        Originally posted by fshead
        "tribo-electric"
        You got that right. =^..^=
