Fusing Unit not Set Correctly
  • mdfurqan2012
    • 194
    Dear All,
    I have a MP5000 which suddenly generates SC672, I replaced controller board than Machine generates SC670, which removed by replacing IOB board, after replacing both boards 'fusing uit set correctly' error occurs, although scanner is working properly.
    I check fusing unit on another machine fusing unit runs perfectly.
    Kindly guide me.
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: Fusing Unit not Set Correctly
    sc672 is a hard disk problem. Lots and lots of treats on this forum tells you that...
    • mdfurqan2012
      • 194
      Kindly guide me for 'fusing unit not set correctly'
      • 8T2
        • Aug 2015
        • 257
        If you plugged everything back in properly when you changed boards...
        Check fuser bearings, particularly Hot Roller bearing on the drive gear side. They are known to seize up and spin in frame when not replaced on time. Nice job getting it out too when they do.
          Mark just told you the code is for the HDD failure....
          what do you think you need to do when you have a HDD error?
          • copier tech
            • 8165
            Did you fit a used or new controller & was it from an identical model?
