Connection Logs
  • Voltageza
    • Jun 2017
    • 71
    [Misc] Connection Logs
  • Voltageza
    • Jun 2017
    • 71
    Re: Connection Logs
    Originally posted by terramobil
    I think there ist no Log showing the reasons of scan errors. Check that the latest Firmware is installed, especially NIB, Scanner and System/Copy. This is the most common reason for scan to folder issues.
    Done all that.
    Firmware up to date
    created local user
    enabled smbv1
    disabled AV
    tried different network interface on laptop
    disabled Firewall
      • 37561
      Re: Connection Logs
      User Tools - Systems Settings - Interface Setting - Print Settings - Last page of the print out.
      • davel
        • Oct 2011
        • 1108
        Re: Connection Logs
        I thought SMB 1 would not work anymore. If so that is your problem.
        • eescamilla
          • Aug 2015
          • 58
          Re: Connection Logs
          Are they Windows 10 computers?
          • Brianneoe
            • May 2015
            • 322
            Re: Connection Logs
            If they are using windows 10 ask if they set up the windows 10 computer with a email account. If so use that account name I.E. "name@abc.com" plus the normal log-in password to authenticate to the folder.
