MPC3002 SC672-001
  • copier tech
    • 8172
    [Error Code] MPC3002 SC672-001
    Hello all,
    I'm faced with an SC672 that wont clear, happens as soon as machine powers on after about 5 seconds.
    Disconnected the fax & HDD, machine wont accept a firmware.
    I have reseated all controller connections, still same.
    Any other suggestions?
    Dont really want to order a controller on this old box.
  • guitar9199
    • Sep 2016
    • 1100
    Re: MPC3002 SC672-001
    Hello all,
    Check the setting of SP5-875-001. If the setting is set to "1 (OFF)",
    change it to "0 (ON)"
      • 37532
      Check the connection between the control panel and the controller.
      • copier tech
        • 8172
        Cant get in SP mode, removed & reseated all connections inc panel USB cable etc.
        Hopefully customer will upgrade...........................
        • MIGUELMARCHENA
          • Feb 2018
          • 195
          Hello
          what done?
          1) I remove the hard drive and the memory
          I enter a system
          I copy the ram
          I erase errors 7807
          turn off
          firmware charge
          turn off
          I connect disco and I put memories
          prendo and full
          sometimes had to erase memory 5801 doing everything else
          You always help me .. I would like you to be able to repay this time
          regards
            • 37532
            If it comes back intermittently, reseat the other end of the USB.
            • copier tech
              • 8172
              Unfortunately its a permanent error, powered off/on multiple times.
              HDD & fax removed same error.
              If customer doesnt upgrade will return to base to work on.
              Appreciate the advice as always. 🙂
              • jonhiker
                • 661
                You may need to replace the controller and the IPU as a set.
                • COPIERMAN
                  • Jun 2009
                  • 559
                  i had one that be find then throw code sometimes right away or day or two later. Turns out was the operation panel was bad. other things can be the usb cable that runs from board in back to the operation panel. my was the op assy.
                  • JDYAL
                    • Sep 2008
                    • 187
                    I've had this code on two different machines a wide format MPCW2200 and a MPC3002. The Mpcw2200 was the controller board and the mpc3002 was the op panel. Not a big fan sc672-001 it will definitely give you nightmares.
                    • MIGUELMARCHENA
                      • Feb 2018
                      • 195
                      I have also done this
                      a controller of the same model, the exchange, let me enter the damage machine, I delete errors update firmware and in which it was fine but now with corrupted controller, I also update firmware ... they are working very well, it is more, as they are I leave them like this or else, I can return the controllers where they are originally and goodbye problems
                      • skinnyb
                        • Jul 2008
                        • 291
                        If it won't boot up without the hdd and fax board it almost always is the controller. Seen it too many times...
                        Sent from my VS987 using Tapatalk
