Real or altered counters
  • fshead
    • 2378
    Re: Real or altered counters
    Originally posted by reglanet
    [QUOTE = JDYAL; 693180] [ATTACH=CONFIG]40345[/ATTACH]
    anyone can cheat if the want to spend time and money.
    When i use to sell 62cpm sharp anaologs there was a dealer who use to send out the
    copier "skins",all to be redone to look new and he would buy brand new mechanical counters.
    At the time i think one could zero out the counters in service mode.
    So if you are buying used machines you need to know who you are dealing with...
    I am lucky i inspect all units b4 paying for them,if a meter is wrong or panels broken etc i ask for a small $ adjustment.
    • MP C5502 Fan
      • Dec 2017
      • 35
      Does the MP C5502 have a mechanical counter as well? If so, where?
      • sturmtrooper
        Copier Combobulator
        • May 2016
        • 587
        I could not find one listed in the parts manual.
        Nevermind, yep it's there.
        • mikadonovan
          • May 2008
          • 2931
          #19
          It's on page U030 Electrical 1 in the parts catalog. Since the 3d parts catalogs suck, I couldnt really tell where its at. Maybe below the IH coil power supply somewhere.
          NEVER ASSUME ANYTHING
          • trc
            • Jan 2007
            • 95
            #20
            Reglanet, PM me and tell me who is trying to sell this machines, and sure i can tell you what they are doing....30 years working in this country.
            • sturmtrooper
              Copier Combobulator
              • May 2016
              • 587
              #21
              On the right rear cover of the duplex door there will be two small punch out panels. The counter sits behind that. Thats where they are on any machine that has that style duplex. For BW machines there will only be a single punch out. Many machines that don't have a counter by default will still have the panel.
              • Gab
                • Aug 2015
                • 677
                #22
                I find it strange that high production equipment is sold with 400,000 / 500,000 copies.
                Ricoh C651 / 751, Ricoh C5100, Ricoh MP9002 etc. Can this be true? How can I know if the
                counters were reduced by some pirate? Is there any way to know?
                Till now i haven't noticed any meter change to any used machines i ordered .
                You can reset electrical counter twice . If you do it third time you will need an new nvram
                • 8T2
                  • Aug 2015
                  • 257
                  #23
                  You know for some people having something really fast is just the issue.
                  Had a MP6000 at a bank that had 80k clicks on it and nobody was connected to print to it or had a user code to use it because it was for management whom all resigned or moved to different departments so nobody could use it...flat spot on pressure roller was so bad you could hear it
                  Sent from my ALE-L02 using Tapatalk
