Opinions on MP5054 and MP6054 performance
  • copyaction
    • Oct 2007
    • 985
  • Tecnicopia
    • Jun 2015
    • 31
    Re: Opinions on MP5054 and MP6054 performance
    Same box outside, diferent parts inside, not the same machine at least, just same family.
    Enviado desde mi Redmi 4X mediante Tapatalk
    • copyaction
      • Oct 2007
      • 985
      Oh, maybe precision roller has it wrong?
      it shows same drum, developer unit, fuser, maintenance kit....
      thats all I was going by.
        • 37379
        Primary difference between high end and low end is the toner cartridge. 24K yield for low end, 37K for high end. Same PM cycles same pm kits. Same manuals.
        • copyaction
          • Oct 2007
          • 985
          Thanks but do they run well?
          are the speeding up a 25ppm machine or slowing down a 60ppm machine?
          • copier tech
            • 8131
            Got a few of these out, excellent model very reliable drum & fuser always go past PM life.
            Best mono model Ricoh have made.
            • Tecnicopia
              • Jun 2015
              • 31
              Umm, i could be wrong. Sorry!
              • apump
                • Mar 2009
                • 160
                I agree. good running copier. fuser is good to about 350k. drum will go to about 250. feed rollers last along time also. I have one that has 900k and I have yet to put feed rollers in it yet.
                • sturmtrooper
                  Copier Combobulator
                  • May 2016
                  • 587
                  The whole 2554-6054, and by extension 2555-6055 series use the same drum and fuser. Many other mechanical parts are the same as well.
                  They seem to do best when used at or above recommended volume. I have a 3554 and 5054 with about 600k on each and about the same age, I think the 3554 is in slightly better shape though.
                  The fusers are sleeve belt design so life will probably suffer a lot if customer does a lot of low page per job copies.
                  • davel
                    • Oct 2011
                    • 1095
                    Different fusers/fusing sleeve.
                    • claudioterrible
                      no mercy...
                      • Oct 2008
                      • 96
                      i have almost 20 of them in rent ,they work perfect!!!!
                      • copyaction
                        • Oct 2007
                        • 985
                        • davel
                          • Oct 2011
                          • 1095
                          [ATTACH=CONFIG]40368[/ATTACH]
                          Apologies, In USA they are the same but 220v countries are different. 4054 will work in 2554 but need to change jumper on plug.
