Ricoh MP C2800 firmware
  • savi0r
    • Sep 2010
    • 363
    [Dead] Ricoh MP C2800 firmware
    Hello. Can someone help me please with the latest firmware available for ricoh mp c2800? I'm having a hard time configuring smb scan on windows 10. Thank you.
  • davel
    • Oct 2011
    • 1107
    Re: Ricoh MP C2800 firmware
    Machine too old.
    • Zeldaman
      • Mar 2011
      • 946
      Hi there!
      In the RICOH generell bulletin 95h are all information you need, also the models which are able to use smb V2/3.
      Greetings...
      • fshead
        • 2376
        i dont know about latest but i think i have a folder wth it laying on my backup laptop.
        gotta ck
          • 37544
          No SMB2/3 firmware available.
          • fshead
            • 2376
            its been a while since i even seen one of these and for scanning i used scan to pdf and twain driver to
            scan to pc
            • sandmanmac
              • 3982
              Setup FTP
              • jonhiker
                • 661
                Either use scan to ftp or scan to email. In windows 10, you can set it to scan to folder using SMB1, some security folks would not recommend it.
                • savi0r
                  • Sep 2010
                  • 363
                  So it can be done using SMB in windows 10? I think i tried enabling SMB1 and it didn't worked. Maybe i'll try ftp scan...
                    • 37544
                    SMB 1 has to be enabled in Windows 10. May have to redo after every security update.
                    • sandmanmac
                      • 3982
                      ....He still requires a F/W update
                      • savi0r
                        • Sep 2010
                        • 363
                        Maybe someone can help me with that...
                          • 37544
                          Precisely what update is needed. Can you identify the problem, other than scan to folder which is a Microsoft update problem? Also what is the current level of all current firmware?
                          • sandmanmac
                            • 3982
                            At a minimum he needs Network F/W Version 8.33
                            NIB Firmware.pdf
                              • 37544
                              [ATTACH]40378[/ATTACH]
                              Without seeing what he currently has, he might already have it.
