shift image in wide format mpw6700
  • en.
    • Jul 2014
    • 124
    hi all
    I have a new installation device when a customer takes a map there is a slight image blurring(shift image ) about 1ml
    i did all correction and sizes but same peoblem
  • JDYAL
    • Sep 2008
    • 186
    Re: shift image in wide format mpw6700
    Could you post an image please. I have about 50 of these in the field I just need to see whats going on before I try to help.
    • en.
      • Jul 2014
      • 124
      [COLOR=rgba(0, 0, 0, 0.87)]Thank you very much for your support and answers to me today. I will tried to bring a sample you and upload to you a form if i can may br i can not because the machine is inside a government building. It is difficult to take out a paper or a form according to the department's policy.[/COLOR]
      [COLOR=rgba(0, 0, 0, 0.87)]But so be aware. Customer prints maps like map type film when is printed . There is skewing in writing and with lines of 1 mm
      [/COLOR]In other words, when the customer makes a match between the original and the copy map, there is a shrinkage and shifting of 1 mm
      [COLOR=rgba(0, 0, 0, 0.87)]Note that there is a another device to it mpw2401 prints the map be adjusted without skimming[/COLOR]
      • JDYAL
        • Sep 2008
        • 186
        What type of media are they printing on....bond paper, translucent, Vellum ??
        Scan a test chart to a jump drive so that you can upload it here.
        There are settings you can adjust in user tools for the media type also make sure that your media cools after a copy, the manual states that the image will shrink a bit after cooling.
        The more info you provide the more I can help. Thanks
        • en.
          • Jul 2014
          • 124
          thanks for your responding ....the original paper type is ( translucent)?WhatsApp Image 2018-08-16 at 1.37.11 PM.jpgWhatsApp Image 2018-08-16 at 1.37.19 PM.jpgWhatsApp Image 2018-08-16 at 1.37.25 PM.jpg
          • JDYAL
            • Sep 2008
            • 186
            Are these prints from a file or copies of an original? What adjustments have you done so far?
            • JDYAL
              • Sep 2008
              • 186
              Also in the images you sent is that one print or a print on top of another print?
              • en.
                • Jul 2014
                • 124
                No my friend this is print copy not print file
                And make adjusment for 1fisrt rool Ao and 914 but nothing change ..then i changed tp A1 like the orginal abd its same problem
                Als i changed som sp mode
                Side to side registration ...leading edge in sp 1001
                • en.
                  • Jul 2014
                  • 124
                  My friend
                  This is to file one the orginal above the copy file and you can see the shifing between the copyeis ther is no maching
                  • JDYAL
                    • Sep 2008
                    • 186
                    So you are trying to get a copy to match an original perfectly? You would spend days changing settings trying to get a perfect match. Scan your image to a jump drive and print 2 copies from that an then they will match.
                    • en.
                      • Jul 2014
                      • 124
                      I did not understand your point .. What do you mean by make scan to jump drive .. Please explain more to help me solve the problem and thank you in advance
                      by the way i connected the device to pc laptop and made scan to folder and i did scan to laptop then when i tried to print the scan file and matching with the original theirs was also shifting and not matching
                      Please help me because you are an expert on the equipment wide format, as I am aware of your words and your answer
                      best regards my friend
                      • en.
                        • Jul 2014
                        • 124
                        best regards
                        • davel
                          • Oct 2011
                          • 1085
                          Is image skewed or is it just magnification out, check your image adjustments page 412 of manual, remember 0.3% is 2.5mm over the width of A0 paper. Your copy could be in specification. Never expect perfection from a copier.
                            hi all
                            i did all correction and sizes but same problem
                            ok is it a blur or offset?
                            are they printing on velum ? ( looks like to me )
                            you are taking a print... scanning it and you have blur/offset or is it STAIR STEPS? what resolution are you scanning from/to?
                            if you print the internal prints what do they look like?
                            what if you print from your lapper ...scan it back? same issue? (ruling out their pc/network BTW did you ever give specs on that?)
                              thanks for your responding ....the original paper type is ( translucent)?[ATTACH=CONFIG]40408[/ATTACH][ATTACH=CONFIG]40409[/ATTACH][ATTACH=CONFIG]40410[/ATTACH]
                              ok SORRY just saw this.. is paper direction top to bottom of the pics?
                              with CLEAR media you might have to reduce scan lamp intensity ( or declare that type to scan ) or have them back up the original with a sheet of bond or opaque )
