shift image in wide format mpw6700
    Re: shift image in wide format mpw6700
    Originally posted by en.
    1)I did not understand your point .. What do you mean by make scan to jump drive ..
    thumb drive - USB stick
    2) by the way i connected the device to pc laptop and made scan to folder and i did scan to laptop then when i tried to print the scan file and matching with the original theirs was also shifting and not matching
    did you preview the file once scanned to your PC? did it display properly?
    best regards my friend
    try the things we have suggested and get back to us.
    • en.
      • Jul 2014
      • 124
      #17
      ok SORRY just saw this.. is paper direction top to bottom of the pics?
      with CLEAR media you might have to reduce scan lamp intensity ( or declare that type to scan ) or have them back up the original with a sheet of bond or opaque )
      yes sir its direction top to bottom ...So that the picture is clear to you .. Simply when the customer makes a copy and then compares the original copy and copy there is a and sekw difference between the two maps by 1 mm
      • davel
        • Oct 2011
        • 1107
        #18
        1mm, within specifications.
        • en.
          • Jul 2014
          • 124
          #19
          what??
          • JDYAL
            • Sep 2008
            • 187
            #20
            There are to many variable on wide format printers. You will never get a copy to match perfectly to an original. Fuser speed, fusing temp, paper feed and all scanning adjustments will never allow this. If you make 2 copies of the same map and overlay them they should be fairly close. If you copy from an original and overlay them they almost always will never line up.
              with every brand I ever work on too!
              • Ctl-Alt-Del
                • Jul 2006
                • 430
                #22
                what??
                If I had a dollar for every time I've told someone, "it's a copier not an originaler"...
                  what??
                  exactly... read SM it will skew/offset specs in there... 1mm is industry standard.
                  • Stormhammer
                    • 150
                    #24
                    That's a good one. I'm copying that one down.
                    • en.
                      • Jul 2014
                      • 124
                      #25
                      ok than;s for your respond ...but there is another device mpw2401 its working without any shifting or skewing
