Rt 43 compatibility
  • mikadonovan
    • May 2008
    • 2931
    Rt 43 compatibility
    Hi All, I hope your day is going well. I am getting ready for an install of several of the 03 series machines. I have been using the trusty old RT43 LCT for years (1075 through the 6001). My question is, will I be able to continue to use it with the 7503's?
    NEVER ASSUME ANYTHING
  • keithxxiii
    Just a tech
    • Nov 2014
    • 468
    Re: Rt 43 compatibility
    7503 is using the RT4040. I don't think you can use it for this one.
    Aye! Cut the crap
      • 37458
      Originally posted by terramobil
      In some cases, components only have a different type designation as of the color of the cover has changed.
      I would give it a try.
      In other cases you may have to replace the control board in the RT, or if it has an onboard rom, replace the rom.
