C5502 SC682-13
  • mikadonovan
    • May 2008
    • 2931
    C5502 SC682-13
    Hi, All. I have a new one here. A sc682-13 is a memory chip at the td sensor error, possibly a bad chip on a dev unit. I would guess the suffix of 13 would point towards the offending unit. Can anybody point me to a list of all the 682 codes? I did not find it in the service manual. Thanks.
    NEVER ASSUME ANYTHING
  • fshead
    • 2376
    Re: C5502 SC682-13
    i cant say if c5502 is the same as what i had on a recent c2800 but the last number "3" pointed to cyan if it does.
    good luck
    • copier tech
      • 8142
      Re: C5502 SC682-13
      good luck
      01=Y 02=M 03=C 04=K
      Usually a force toner supply & dev init on the relevant unit will rectify the error (personal experience)
      • mikadonovan
        • May 2008
        • 2931
        Re: C5502 SC682-13
        I used the table for rfid errors(may be right or wrong), and replaced the magenta pcdu. Since the code was only logged and not shown, next time I return I should have no more of this code on the SMC. Time will tell.
        • mikadonovan
          • May 2008
          • 2931
          Re: C5502 SC682-13
          They called back yesterday with a "photoconductor unit not set" problem. I went ahead and replaced all the pcdu's and brought the old ones in to troubleshoot. The M unit obviously was not the one at fault.
