MP C6004ex Scan to Multi Page TIFF
Re: MP C6004ex Scan to Multi Page TIFF
I only work with the classic screens, but I know you can do it from the new scanner screens also. From the classic scanner screen Press [Send File Type / Name] and you can choose multi page tiff and then program as default as needed.Totoro -
The setting for multi page TIFF does not appear:
That's what makes me wonder if there is an SP to change that.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
Sent from my VS987 using TapatalkComment
Looking at a machine we have here unless you have B&W set, Multi-page Tiff is greyed out.
The manual states:
Single Page [TIFF / JPEG]
- Originals scanned in black and white are sent as TIFF files.
- According to the settings specified for [Compression (Gray Scale / Full Color)] in the [Send Settings] tab under [Scanner Features], originals scanned in full color or gray scale are sent in one of the following file types:
- [On] : JPEG file
- [Off] : TIFF file
- [On] : JPEG file
Multi-page [TIFF] or [PDF]
- When [Full Color: Text / Photo], [Full Color: Glossy Photo], [Gray Scale], or [Auto Color Select] is specified in the [Original Type] tab under [Scan Settings] and [Compression (Gray Scale / Full Color)] is set to [On] in the [Send Settings] tab under [Scanner Features], you cannot select [TIFF] under [Multi-page].
- Even if you select [TIFF] under [Multi-page], files stored in JPEG format are automatically changed to multi-page PDF files and then sent.
So looks like it still isn't possible even on the newer kit.
