MP C6004ex Scan to Multi Page TIFF
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3945
  • totoro
    • 568
    Re: MP C6004ex Scan to Multi Page TIFF
    I only work with the classic screens, but I know you can do it from the new scanner screens also. From the classic scanner screen Press [Send File Type / Name] and you can choose multi page tiff and then program as default as needed.
    Totoro
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3945
      The setting for multi page TIFF does not appear:
      That's what makes me wonder if there is an SP to change that.
      • skinnyb
        • 291
        [ATTACH=CONFIG]40454[/ATTACH]
        Tiff is single page on all Ricoh I have ever used lately. Not sure about older models. And B&W only. If you go to color it makes a jpeg.
        Sent from my VS987 using Tapatalk
        • engineers
          • 51
          Looking at a machine we have here unless you have B&W set, Multi-page Tiff is greyed out.
          The manual states:
          Single Page [TIFF / JPEG]
          • Originals scanned in black and white are sent as TIFF files.
          • According to the settings specified for [Compression (Gray Scale / Full Color)] in the [Send Settings] tab under [Scanner Features], originals scanned in full color or gray scale are sent in one of the following file types:
            • [On] : JPEG file
            • [Off] : TIFF file
          Multi-page [TIFF] or [PDF]
          • When [Full Color: Text / Photo], [Full Color: Glossy Photo], [Gray Scale], or [Auto Color Select] is specified in the [Original Type] tab under [Scan Settings] and [Compression (Gray Scale / Full Color)] is set to [On] in the [Send Settings] tab under [Scanner Features], you cannot select [TIFF] under [Multi-page].
          • Even if you select [TIFF] under [Multi-page], files stored in JPEG format are automatically changed to multi-page PDF files and then sent.
            So looks like it still isn't possible even on the newer kit.
          • Kimi
            • Feb 2018
            • 105
            Turn off full colour compression under send settings and VOILA, colour multi page TIFF.
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3945
