Pro 1107ex
  • douglas
    • Jul 2025
    [CQ] Pro 1107ex
    Copies running light after a while. Replaced developer, New toner hopper , pipes all cleaned, and clear, toner supply motor New. Tones up after force toner supply . Did all the settings for light copies. Toner rate on 650.Also replaced development unit mag roller bearings. Development unit on 3 and a half million. Machine 21 million copies.Thanks Douglasc
    • 37489
    Re: Pro 1107ex
    Try the following:
    SP 2210 ID Sensor Pattern Interval change to 1
    If happening during long print runs change SP 2506-001 to 1 and -002 50.
    • eccelobo
      • 113
      Re: Pro 1107ex
      Replace the toner cylinder (the one before the pump). It happened to me and that was the solution.
      Good luck!
      Enviado desde mi SM-G920V mediante Tapatalk
      • davel
        • Oct 2011
        • 1104
        Re: Pro 1107ex
        How are all PCU pm parts, I would think you may need to replace dev unit.
        • Firoozshayan
          • Oct 2021
          • 1
          Re: Pro 1107ex
          I think you should clear all the file in machine then send a new file and do print
            • 37489
            Re: Pro 1107ex
            What the fuck are you talking about idiot? This thread is over 3 years old, dead and was buried. Go away ghoulish grave robber.
