MPC3003 SC995-01
  • digicor
    • Jul 2008
    • 1153
    MPC3003 SC995-01
    I have the 995-01, but the serial number is whats on the controller, what else could cause this, whats the fix? is there a fix?
    do i need to get new NVram and matching eeeprom?
    or is the controll board shot? it comes to ready for about 15 seconds then throws the 995-01
    ideas please?
  • tufbnme
    • 493
    • mincopier
      • Dec 2015
      • 289
      Re: MPC3003 SC995-01
      Need to go into the "Super Secret" service mode to rest the serial numbers. There is a listing of three there and they all three must match up. Two of the three can be changed.
      • kplow1986
        • Nov 2013
        • 41
        ideas please?
        1. make sure u get correct cpm for this model. 30 and 35 is different controller.
        2. make sure machine serial is match. goto factory mode to change.
        • digicor
          • Jul 2008
          • 1153
          ran service mode /reset143c/c re typed in the sn in that was in the last one , into the other two sections, done, im not sure how the sn got changed from the first two , from the third , but its all good now
          so if yo have this problem enter service mode reset143c/ hold the c and there will be three sn slots , make sure they all three match
          • GeorgeBest
            • Jul 2009
            • 520
            Super secret mode is ?
            And in what Section can I reset the seriel number
            Thx in advance
            • GeorgeBest
              • Jul 2009
              • 520
              HI,
              What is " reset143c/c" ?? In what SP section is that?
              Thanks in advance
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Originally posted by GeorgeBest
                HI,
                Thanks in advance
                This is old thread 143 is factory service mode
                Regards Mark
                • GeorgeBest
                  • Jul 2009
                  • 520
                  Don't know what you mean here, must get rid of the SC995-01
                  entering on three places? Only see SP5811-002 and SP5811-004 . . .
                  given me a headache ....
                    • 37372
                    You should not have to get into Factory Service mode as long as you followed the proper procedure the very first time power was applied after changing the BCU, Controller.
                    Set serial number on new BCU
                    Open the front cover.
                    1. Turn the power on. SC995-01 occurs immediately.
                    2. Make a note of the number that is displayed in SP5-811-005.
                    3. Enter the number that you noted in SP5-811-004.
                    4. Turn the power off.
                    5. Close the front cover
                    • mgipa
                      • May 2020
                      • 49
                      ideas please?
                      • GeorgeBest
                        • Jul 2009
                        • 520
                        I dont see SP5811-005 . . . as I said, only 002 and 004
