MP3054
  • GeorgeBest
    • Jul 2009
    • 526
    MP3054
    Hi,
    when you change the PCDU unit on this one, it adjust the developer and ID sensor itself ?
    Because changed at two machines the complete PCDU, now both customers complained about light images, copy as well prints.
    Is there an SP mode to adjust?
    No much experience on this one
    Thanks in advance . . .
  • francisco
    • Nov 2009
    • 168
    Re: MP3054
    Originally posted by GeorgeBest
    Hi,
    when i change the pcdu ,i always adjust developer inicial setting (2-801)
    • GeorgeBest
      • Jul 2009
      • 526
      Re: MP3054
      mabey I am wrong, but there is no SP2801 (?)
      • francisco
        • Nov 2009
        • 168
        Re: MP3054
        sorry, 2801 was in older models.
        sp 3011 manual procon exe, 3012 to see if it is ok
        but if you turn sp 3701-xxx to 1 and turn off ,the machine do autm .
        • copier tech
          • 8238
          Re: MP3054
          Hi,
          I always rebuild these units, much cheaper to replace OPC, Blade, Charge roller, charge cleaning roller & developer.
          As per service manual reset couters & init developer.
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            Re: MP3054
            Make sure that the bung was removed from the dev opening on the PCDU....very easy to miss.
            The copies will start out fine then go light due to no toner being added to the dev.
            • senesdad09
              Re: MP3054
              Agreed, done it myself! Also, definitely make sure that you have either done SP3701 OR go into the PM counter menu at the main service mode screen, and change new unit to yes (some you just press the button) then it will tell you to restart and automatically perform the necessary adjustments.
