MP 9000 Ricoh
  • info@digitaalprint.be
    • Aug 2016
    • 33
    MP 9000 Ricoh
    Machine has gone on standby during a run.
    She stays that way. no further response from the machine.
    All power boards replaced and no result.
    Anyone have an idea? thanks
    Patrick
  • eccelobo
    • 113
    Re: MP 9000 Ricoh
    Check the fuser thermostats for continuity.
    Also, check the drum potential sensor for dust or bad connection.
    Good luck!
    Enviado desde mi SM-G920V mediante Tapatalk
      • Aug 2016
      • 33
      Re: MP 9000 Ricoh
      Everything changed with a machine that works and no results. Thanks anyway.
      Patrick
      • keithxxiii
        Just a tech
        • Nov 2014
        • 471
        Re: MP 9000 Ricoh
        There's firmware that fixes this issue.
        System_Copy firmware ver 3.01.1 or later
        LCDC firmware ver 1.11 or later (Language firmware ver 0.71 or later)
        Printer firmware ver 1.26 or later
        Websys firmware ver 1.08 or later
        WebUapl firmware ver 1.06 or later
        Scanner firmware ver 1.13 or later
        Aye! Cut the crap
        • anothertech
          • 1771
          Re: MP 9000 Ricoh
          Patrick
          What does that statement even mean?
            • 37556
            Re: MP 9000 Ricoh
            He swapped parts with another machine.
              • Aug 2016
              • 33
              Re: MP 9000 Ricoh
              Wire from the toner pump was short-circuited with the mass.
