Looking for feedback on hooking up a mpc401 where there is no access to router..
  • fshead
    • 2378
    #16
    Re: Looking for feedback on hooking up a mpc401 where there is no access to router..
    If you have placed it where he wants it and there is no network connection at that location, the installation is complete.
    if it was that simple,i do wish..
    • mikadonovan
      • May 2008
      • 2931
      #17
      Originally posted by Oze
      Buy a cheap wireless range extender and build into the cost of the machine.
      Plug ethernet cable into extender.
      Push the WPS button on the range extender and then the WPS button on the router.
      Job done
      Worse comes to worse if the WPS route doesn't work give the machine an I.P address within range of the router.
      I did an install just the other day this way...worked like a charm.
      I also did this about a year ago, and it works great. No network related calls have been reported.
      NEVER ASSUME ANYTHING
      • Dannymanno
        • Mar 2017
        • 2
        #18
        TP link do cheap 'Travel Routers' they have a function called client mode allows you to bridge the wireless and create an ethernet out, easy to set up and do a good job!
        • Mealstech
          • Mar 2017
          • 10
          #19
          Ive used the cheap wifi extender route many times. It works pretty well as long as the extender is decent. I like the linksys extender with the cord option the best. You can even attach it to the back of the machine. If you need to set up the extender, just hook it directly to your computer and the manual will tell you the link to put in your web browser to set it up. Most extenders will walk you through the process.
          Another trick I have used is to take a computer near by, wire the copier to it and bridge the wired and wireless connection on the computer. You would have to set static IP's and the computer needs to stay on to give connection to the copier, but it works.
          I would stay away from the SOP wifi if you plan on using anything other then just printing. The Android panel is technically a separate device from the rest of the copier. They achieve network connection through port forwarding different services. Ricoh hasn't really done that a lot to make the machine available through the SOP's personal wifi.
          • fshead
            • 2378
            #20
            Thanks all..
            The deal fell thru,a real odd fella..
            "Another trick I have used is to take a computer near by, wire the copier to it and bridge the wired and wireless connection on the computer. You would have to set static IP's and the computer needs to stay on to give connection to the copier, but it works."
            I do that a lot and now keep a few spare 5 port hubs wth me all the time in my car.
            A quick easy connection.
