Looking for feedback on hooking up a mpc401 where there is no access to router..
  • fshead
    • 2378
    HI
    I have to deliver a mpc401 to a "cottage" where they have wireless but cant get to the wired hub or router.
    I connected it up to my laptop in my shop using the usb port but wondered if there is another option.
    A crossover cable? I do have an wireless option i pulled off a mpc3502,would that work in a mpc401?
    what would you do?
    thanks
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: Looking for feedback on hooking up a mpc401 where there is no access to router..
    Originally posted by fshead
    HI
    what would you do?
    thanks
    Buy a cheap wireless range extender and build into the cost of the machine.
    Plug ethernet cable into extender.
    Push the WPS button on the range extender and then the WPS button on the router.
    Job done
    Worse comes to worse if the WPS route doesn't work give the machine an I.P address within range of the router.
    I did an install just the other day this way...worked like a charm.
      • 37652
      HI
      what would you do?
      thanks
      If you are talking about the internal wireless option, I would avoid it. I prefer something like the NETGEAR NE300. Provides a single CAT 5 connection that can be used for the MP C401 or connected to a work group switch to connect additional devices. Usually under $50.
      • fshead
        • 2378
        thanks all.
        AS I dont know this accnts situation,for all i know he might be hijacking his neighbors wireless network and if so
        he will not be able to press WPS button on the router.. So basically adding the ne300 makes the connection wireless but how does one enter the WEP and such?
        • Kimi
          • Feb 2018
          • 105
          Does it have the SOP? If so you can use WIFI.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            I totally agree.
            It’s not even worth checking to see if the wireless option is the same.
            Far too persnickety and unreliable.
            There are simply too many other solid and inexpensive solutions out there (such as what SlimSlob mentioned) to put up with the agony.
            Another thing to consider...if you go the route of a USB connection, you’ve just precluded the scanning option. Scanning (push or pull) is a network-only proposition.
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              thanks all.
              • fshead
                • 2378
                Thanks but no SOP on this one..
                NOP..
                • fshead
                  • 2378
                  The way i see it if he is all i want is to finish the install and get paid...
                  He may not be doing such but he did say running a network cable was "not possible"..
                  As for scanning he can always scan to usb on side panel,no biggie..
                  thanks for all the info
                  • sandmanmac
                    • 3990
                    I typically just connect my range extenders manually regardless of WPS availability -it still only takes a minute or 2.
                    I'm not familiar with the model suggested, but the instructions will be in the package, and they're all very similar. Typically it's as simple as plugging in the extender, and connecting my laptop directly to it with a network cable, logging in to the ip address of the unit and following the instructions. It will find all available networks just like any other wifi device. Connect to the proper network and save changes, the plug the copier in to the extender and proceed as usual.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                        • 37652
                        If you have placed it where he wants it and there is no network connection at that location, the installation is complete.
                          • 37652
                          thanks all.
                          Hopefully they are not using WEP, Wired Equivalent Protocol. It is only slightly more secure than an unsecured WIFI.
                          • copier tech
                            • 8237
                            I use the Apple Airport Express to enable wifi on any printer or copier (that does not have it built in) very stable never drops off & support for SMB, scan to email etc.
                            • fshead
                              • 2378
                              thanks..
                              I figured laptop would configure the initial connection.
                              I am going to suggest both option,simple print to USB or the range extender,I just dont want to spend
                              time i dont have to explain to customer how system works and what to do if it loses signal..
                              HEY sandmanmac Any shows you going to?
                              I am going to see OZZY this week at the beach,should be entertaining
