red is orange
  • bunnthebody
    • Oct 2008
    • 38
    [CQ] red is orange
    I have a Ricoh SP C242 that prints red as orange. All colors show up on the maint. page, as well as the red block. I tried a driver from another ricoh that made it worse. Ordered a new set of drums. Any help would be appreciated
    Thanks Roger
  • mikadonovan
    • May 2008
    • 2931
    Re: red is orange
    On the Ricoh models I work on, usually a good ID sensor cleaning will bring back decent color. Obviously, if the drums/developers are worn they would need replaced.
    NEVER ASSUME ANYTHING
    • guitar9199
      • Sep 2016
      • 1100
      Re: red is orange
      Are they using genuine toner, or aftermarket?
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        Re: red is orange
        If you are comparing the colour of a print to the colour on a monitor, you may be in for a shock if the monitor isn't properly calibrated.
          • 37532
          Re: red is orange
          Also the monitor is RGB color where as the C242 is CMYK. In addition, the monitor is emitted light and the copies are reflected light.
          • guitar9199
            • Sep 2016
            • 1100
            Re: red is orange
            Color Theory 101!!
            ....I dang near fell asleep reading all that stuff!
            • rthonpm
              • Aug 2007
              • 2859
              Re: red is orange
              You may want to look at installing the ICM files for this model on any systems using it, or the print server. While not every application can benefit from them, I've seen huge differences in output from having them installed.
