ricoh pro c5200s shows jam but theres no jams
  • dalewb74
    • Feb 2018
    • 1153
    this copier shows a jam in the LCIT 4050 and displays a J007. but whenever you open the 4050 there is no paper jam, and when you close it it starts printing again. i have tried increasing and decreasing the fan. and have also replaced the paper feed rollers. any ideas on what is causing this? thanks for your help. i have noticed when changing the fan speed that i get a J015 and there is an actual jam.
    • 37490
    Re: ricoh pro c5200s shows jam but theres no jams
    I believe that J007 is a tray 1 failure to feed and J015 is a failure to reach LCT F3 Transport sensor. What type of paper is being used? Have you tried feeding it from a different tray?
    • dalewb74
      • Feb 2018
      • 1153
      it feeds fine from the other trays. it just when using the additional 2,200 large capacity that sits over to the right of the machine that it has the J007. it's the LCIT RT4050. we have tried different sizes paper, which gets the error. but we haven't used a heavier weight. i believe its a 24lbs.
      • dalewb74
        • Feb 2018
        • 1153
        something i forgot to add is we have also tried different brands of paper, same weight and such with the same result.
          have you cleaned the sensors in the LCT?
          run the sensor test and find out which sensor is flakey
          • dalewb74
            • Feb 2018
            • 1153
            i have the service manual. but the only sensors i am finding says TM/P front, center, and rear. but doesn't identify front, center, and rear of what. i have no way of knowing if it's for ADF or whatever.
              • 37490
              Hire a trained technician.
                Ricoh has the accessories ( finisher/LCIT ect ) in separate manuals .... try looking in PARTS manual for the location of sensors
                • Oscar57
                  • 79
                  Hi,
                  I'm having the same exact problem. Did you ever find out what was causing this to happen?
                    • 37490
                    Originally posted by Oscar57
                    Hi,
                    This thread is nearly 2 years old. We considered that dead and buried. We don't like grave diggers. Start a new thread. Include as much detail on your problem as you can.
                    • mrwho
                      Major Asshole!
                      • 4299
                      And, if you reach a solution, please post it in the thread - although this thread is dead and buried, we still don't know how the op solved his problem...
                      Mascan42
                      Ibid
                        Being 2 years and no reply, I don't think we will ever find out.
