Aficio sp5210 user counter does not register consumption
  • MIGUELMARCHENA
    • Feb 2018
    • 189
    GOOD DAY
    in an sp5210 hobby when printing the consumption report for collection, it appears that several users appear without consumption, it appears in 0.
    This has not happened to me before, but in the Panasonic it was configuration problems in the driver so I assume it will be the same.
    I suggested to the network administrator the reinstallation of the driver but as you already know, the problem is always in the machines until they are proven that it is not so.
    Is there a missing step or can it be the machine?
    Thank you
    • 37403
    Re: Aficio sp5210 user counter does not register consumption
    I know consumption was a term used for tuberculous but I didn't know machines could catch it.
    • MIGUELMARCHENA
      • Feb 2018
      • 189
      • sandmanmac
        • 3980
        Are you just taking their word for it, or have you actually tested it yourself by using the codes that apparently show no usage and then printing the report again?
        Sounds to me like "several users" may be using someone else's user code.
        Just a thought....
          huh? english please
            • 37403
            huh? english please
            I think he doesn't like my joke.
            • copier tech
              • 8131
              Just a thought....
                i read a lil french and english...
                i wish people would reply in english... IMHO kinda rude
                • MIGUELMARCHENA
                  • Feb 2018
                  • 189
                  thanks for answering tomorrow I'll see it, there are 90 users 10 who do not register the meter Tomorrow I inform thanks Thank you for answering
                  • MIGUELMARCHENA
                    • Feb 2018
                    • 189
                    no muestran usotomorrow I reviewThank you
                    • MIGUELMARCHENA
                      • Feb 2018
                      • 189
                      • keithxxiii
                        Just a tech
                        • Nov 2014
                        • 468
                        Thank you google translate...
                        Hi,
                        just wanna share though, if user code authentication is enabled and print driver is configured properly (job type, user ID) and of course no duplicate CODES, then there should be no problem on the records. But 90 users? How'd you even manage that?
                        Aye! Cut the crap
                        • MIGUELMARCHENA
                          • Feb 2018
                          • 189
                          HI GOOD DAY
                          I went to the office
                          they have 2 sp5210 ... one good, no problem, the other was the one that did not register impressions.
                          many mistakes
                          there was no printing restriction on the machine,.
                          Choose to copy the notebook and erase the hard drive erase errors etc
                          I returned to intalar the notebook.
                          Now, on computers ...
                          codes with numbers more than established, codes numbers less
                          codes were missing in the boxes of the driver etc
                          already shown to the network administrator
                          once again as in 99% of the time it was not the machine, it was the bad execution of the network administrator
                          thank you very much everyone for your valuable contributions
                          regards
                          • copier tech
                            • 8131
                            Hi,
                            I had to set up 150 user codes at a school once!
                            • MIGUELMARCHENA
                              • Feb 2018
                              • 189
                              Well I thought I would have to configure each user again, explain the problem to the administrator and goodbye .... the erroe was from the ..... greetings
