counter without @remote
  • miro
    • Feb 2010
    • 87
    Regards,
    Does Ricoh have anything to email the counters, errors, etc, from the machine automatically without software on the customers network (
    @remote).
  • zed255
    How'd ya manage that?
    • 1024
    Re: counter without @remote
    Counters via email can be set up on recent products in SP mode, or using a SOP app.
    • miro
      • Feb 2010
      • 87
      Zed255, thanks,
      can you tell me more info, where in SP mode, which setings.
        • 37533
        Don't waste your time in SP mode. Use the SOP Designer Tool. Load it on your laptop and use it to configure the SOP on all new machines going out. You get to specify what day of the month and time of day that it is sent, You can also put your company logo on the wall paper.
        • miro
          • Feb 2010
          • 87
          thanks Slimslob,
          but what with older mashines, like MPc 2051/3001/3002, without SOP
            • 37533
            Originally posted by miro
            thanks Slimslob,
            You're stuck with either @remote or having to either get the customer to print the counter sheet and fax it to you or send someone out. SmartDevice Monitor for Admin can be downloaded from Softpedia. It can scan for devices on a network and put current meter counts from them. The result can exported to a spreadsheet.
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              There's always FMaudit.
              It can collect meters and report toner levels(and flag toner out) on ALL machines on the network.
              Needs to either be installed on the customer server or any pc that is always on.
              Managed Print Services Software | ECi FMAudit(R)
              • copier tech
                • 8176
                Interesting, I don't believe this is available to us in UK!
                Would you be will to share!?
                • Kimi
                  • Feb 2018
                  • 105
                  All MFDs have an auto email notification setting on the web page. It will send everything but counters.
                  • Kimi
                    • Feb 2018
                    • 105
                    Its on My-Ricoh, go to publications and search SOP designer.
                    • lordamet
                      • Apr 2020
                      • 17
                      hello, do you found the solution?
                        • 37533
                        Your first post and you had to go grave digging.
                        If you have a problem start your own thread.
