Mp 9000 random smudge... I'm gone mad!
  • Codex
    • May 2008
    • 704
    Hello guys
    I have an Mp9000 thats driving me crazy... It seems the machine is possesed by the devil. Randomly a smudge appears on the first copies /prints.... Ever on the same height on the sheet but not on the same place, then after two or three xopies/prints the smudge disappears for days or sometimes for weeks..... I've swapped the following from a working machine : drum, cleaning assy, development unit, pcu frame, laser diode, polygon motor, transfer unit...... But the problem still occurs....
    Inviato dal mio SM-G935F utilizzando Tapatalk
    Memento Audere Semper
  • dave w
    • Jun 2015
    • 230
    Re: Mp 9000 random smudge... I'm gone mad!
    Have you looked at the Transfer Belt?
    • mikadonovan
      • May 2008
      • 2931
      You might try a new charge assembly, kinda looks like a charge problem and you didnt say you replaced it. It doesn't look like a fusing issue,either.
      NEVER ASSUME ANYTHING
        • 37532
        For as lomg as I can remember, black smudges on the first copy are an indication that it is far beyond PCU PM. A spot on the drum is not properly taking a charge. By the second page there is sufficient charge buildup. Include a new drum when you do the PM.
          Originally posted by Codex
          Hello guys
          Why do people make this job harder than they need to?
          you swapped all those parts and NOT the FUSER? think about WHAT put toner on the page or BONDS it to the page!
          • JDYAL
            • Sep 2008
            • 187
            I'm with Mika looks like a charge problem. I see this on wide format when the charge corona starts to go, and its intermittent.
            • eccelobo
              • 113
              X3 charge corona. It happened to me.
              Enviado desde mi SM-G920V mediante Tapatalk
              • Codex
                • May 2008
                • 704
                I swapped both charge assys from a working machine.... Still the same problem after a week...... I'm sure it's not a fuser problem
                • Codex
                  • May 2008
                  • 704
                  I'm sure its not a fuser problem
                  • Codex
                    • May 2008
                    • 704
                    It looks lime some electrical discharge
                    • Codex
                      • May 2008
                      • 704
                      I changed the drum from a working machine... But still the same problem
                        • 37532
                        Quit f***ing swapping parts and start replacing with new. I would include the connector for the corona and the HVPS.
                          • 37532
                          What part of new do you not understand.
                          • JDYAL
                            • Sep 2008
                            • 187
                            Check the power packs- ppg ang cgb
                            • NeoMatrix
                              Senior Tech.
                              • 3513
                              Does the smudge appear when coping through the ADF only ,off the platen glass only , print only?
                              Do you have an sample copy for the different times the problem occurred?
                              Lets say a sample of the fault for Monday, and a sample of the fault for Friday.
                              Can you overlay the sample copies one on top of the other, hold them up to the light; is the fault blurb an exact match ?
                              If the blurbs are an exact match you can rule out insects or rodents moving around in the optics.
                              I would lean toward quenching lamps/laser.
                              Maybe paper dust build up behind the rego roller???
                              The above might jog a light bulb in someone.
