Mp 9000 random smudge... I'm gone mad!
  • mikadonovan
    • May 2008
    • 2931
    #61
    Re: Mp 9000 random smudge... I'm gone mad!
    Ok, new idea. Some liquid is finding its way onto the drum surface, maybe lubricant from an overactive can of wd40. Or, there may be contaminent in the toner .
    NEVER ASSUME ANYTHING
    • Lagonda
      • Aug 2008
      • 1649
      #62
      Going way back into the dim distant memory of my past I suddenly thought about the old dye line plan printers and the slightly corrosive ammonia fumes they used to give off. Your problem machine doesn't live next to one of those does it?
      • Codex
        • May 2008
        • 704
        #63
        No... Only Mfp in that shop
        Inviato dal mio SM-G935F utilizzando Tapatalk
        Memento Audere Semper
        • Mark Bbb
          • Jun 2012
          • 1662
          #64
          Big trouble in little Sicily!
          • Codex
            • May 2008
            • 704
            #65
            Changed HV Boards today.... Let's see what happens...
            • ccfc87
              • Feb 2014
              • 18
              #66
              Could be a stab in the dark...but have you tried looking at a lag in Drum drive maybe...
              • BLADE
                former propeller tester
                • 478
                #67
                what does 'ammonia paper' do to machines?
                • NeoMatrix
                  Senior Tech.
                  • 3513
                  #68
                  Gecko pee(weak ammonia?) does wonders to drums and circuit boards...
                  Mouse pee is a tad better than gecko pee, probably because there's a lot more of it.
                  Mice wee stinks bad and corrodes circuits boards quite good....
                  Never tried ammonia directly on a selenium drum.
                  Ammonia cleans grubby carpets quite okay though.
                  • exCSER
                    • Mar 2009
                    • 98
                    #69
                    What about some type of airborne cleaning agent or air freshener being sucked up by the airflow through the machine while in standby mode for a long period of time?
                      • 23008
                      #70
                      Like chlorine, at a public pool? Within a few months everything ferrous will be rimed with rust. =^..^=
                      • NeoMatrix
                        Senior Tech.
                        • 3513
                        #71
                        Re Chlorine and iron.
                        Yes chlorine rusts iron, hydro-chloric acid is by far a lot quicker.
                        As you probably know, Ferric-chloride eats copper rapid, this is how circuit board tracks are etched.
                        Interesting point though BC.
                        I wounder if chlorinated water rusts/oxidises the iron inside the human body. Could this oxidise effect be a cause of anaemia(lost of iron/minerals) in some people ????
                        Chlorine is neutralised by sunlight, but how much sunlight for how long before we should drink the city tap water? Here in our location the "water board" places "booster cylinders" of chlorine directly inline with residential housing water mains. Those booster cylinders of solid chlorine have no reaction to sunlight before the water comes out of the house tap. Does this chlorine create an oxidising effect within the iron of a person body before it has a chance to react with sunlight ?
                        An of cause every other chemical placed into the city water supply. Eg. Aluminum Oxide (Al-Ox). Fluoride.
                        Our water supply comes out pure white some days. We have to run the tap for a few minutes just to wash.
                        --mes'a thinking.
                        (parody jar jar binks)
                          • 37510
                          #72
                          Re Chlorine Chlorine is neutralised by sunlight, but how much sunlight for how long before we should drink the city tap water?
                          Sunlight will burn the chlorine off the first 12 inches of water in a swimming pool in about an hour.
                          • Codex
                            • May 2008
                            • 704
                            #73
                            UPDATE!!!
                            Hello guys, i'm almost sure the problem is solved....last thing i changed three weeks ago was the HV Board for the charge unit, till now (crossed fingers)...no problem!!!
                            • Lagonda
                              • Aug 2008
                              • 1649
                              #74
                              Originally posted by Codex
                              UPDATE!!!
                              Thanks for getting back to us with a result, not many techs who ask for help can be bothered. Hope it stays fixed for you.
                              • Mark Bbb
                                • Jun 2012
                                • 1662
                                #75
                                I would say, Sicily is saved!
