noisy fuser in MP C2011,MP C2003sp
  • Marwanalhajbi
    • Jul 2018
    • 72
    [Misc] noisy fuser in MP C2011,MP C2003sp
    i have a noisy fuser gear,it begins after a sleep or printing ,in MP c2011 and MP C2003 or any multifunction having same fuser shape??
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: noisy fuser in MP C2011,MP C2003sp
    Fusing pressure release/exit motor motor.
    AX060435 is the part number.
    Maybe check the state of the fuser drive gear in the picture as well.
    • Marwanalhajbi
      • Jul 2018
      • 72
      i have checked the MOTOR and all gears of fuser,all in good shape,plus it work just fine but the noise is so loud
      • Mark Bbb
        • Jun 2012
        • 1662
        the fusing unit will become noisy if the customer have used thick paper without indicating it on the machine.
        Even if he have does that for a few papers, it could end up making noise.
          • 37652
          What Oze is referring to is that in operation the pressure roller release over shoots and has to cycle again, usually, multiple times.
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            Yep...and the resulting noise is quite loud and obnoxious.
            The single motor controls fuser pressure release AND exit assy drive...a really dumb idea and we've had them fail a month after install.
            Go into OUTPUT SP mode and test pressure release motor...turn it on/off and see if it makes the noise.
            Tech skills 101
