SC406 error on Savin 3406WD Wide format
  • Jbaines
    • 2
    wide format just started printing light to blank pages mid job then threw SC406 code.
    machine was fine 2 days ago when I replaced a broken caster.
    inspected, belts, tensioners, corona wires, charge, transfer and separation wires, drum, blade, ID sensor.
    machine only has 6150 feet on it. cant tone up with forced toner add.
    was looking at the Charge pack but it looks like many folks have already gone the same path I was considering.
  • davel
    • Oct 2011
    • 1103
    Re: SC406 error on Savin 3406WD Wide format
    Check the drive to toner unit.
    • keithxxiii
      Just a tech
      • Nov 2014
      • 468
      What is the value of PWM setting when you initialized it? Is the ID sensor connected properly?
      Aye! Cut the crap
      • JDYAL
        • Sep 2008
        • 187
        1.Check developer drive gears. 2. make sure that connector is securely plugged into the drum unit. 3.check drive belts, sometimes they look fine but are worn enough to cause problems.
        • JDYAL
          • Sep 2008
          • 187
          Just wanted to add one thing. If you had to replace a caster that means that the machine was probably not level for a time. These machines will eat belts and gears when not level.
