Ricoh MP301 bad hard drive
  • COPIERMAN
    • Jun 2009
    • 559
    I have a customer that pick up copier cheap. Has use it for a while and now hard drive has gone bad. He only use copier to make copies. Is there away to tell copier that it doesn't have one in it so the code wont show up on display. It still makes copies but he like code not to show up if possible. Any help will be appreciate i look in service manual but i don't see any thing to turn off hard drive function.
  • sandmanmac
    • 3981
    Re: Ricoh MP301 bad hard drive
    Apparently, you haven't tried anything yourself -like simply disconnecting it? Even though I'm not sure if that would help or not. How about reformatting it?
    Otherwise, why not pickup a used 2.5" HDD for $10 (or less)and pop it in
    • mincopier
      • Dec 2015
      • 289
      What is the code? I don't believe MP301"s came with an HDD but they were an option. On Ricoh generally disconnect the HDD and the machine does not look for it.
      Just looked at the service manual and there is no SP modes to change when installing. So you should just be able to disconnect at the board and be done.
      • Gift
        • Mar 2011
        • 2459
        HDD was indeed an option and not required for most functions. I think some direct print-from or scan-to USB might not work without HDD option, perhaps Airprint, too but everything else will do it's job without HDD.
        • COPIERMAN
          • Jun 2009
          • 559
          i have already tried disconnecting hard drive from unit and comes up on display letting you know that it is not connected hard drive failure and then tells you email wont work etc. and of course give me sc codes to go with it.
          • davel
            • Oct 2011
            • 1104
            Just get another HDD.
            • copier tech
              • 8144
              Any 2.5" hdd will work simply fit another.
              But first i'd try formatting your original one, either in service mode with SP5-832-002 or fit the drive to a caddy etc & format in Windows.
              • sandmanmac
                • 3981
                Then do what I also suggested and invest $10 frigging dollars in a new (used) one!
