Ricoh scan folder time
  • COPIERMAN
    • Jun 2009
    • 559
    i have a customer that has a new PO software. When they email from copier and receive document they need it to be in normal time not military time. I have look in user tools scanner features also in service mode and doent see where i can change it. I was wonder if someone can tell me how to change time. Thanks for any help in this matter.
    • 37483
    Re: Ricoh scan folder time
    How about the model number?
      • 37483
      Could be a function of the email server(s) sent through, the email program used to receive or the OS on your computer.
      • mincopier
        • Dec 2015
        • 289
        Have you tried emailing yourself from the copier to wee what the time comes across as. Ricoh devices are usually in the "normal" 12 hour format by default.
        • copier tech
          • 8144
          Is the time set in the copier correct?
          • COPIERMAN
            • Jun 2009
            • 559
            Ricoh Mp 2000 is copier I have attached and PDF showing what i am looking to change
            • copier tech
              • 8144
              Thats the time of the copier, so set the copier time as per your client request.
              • COPIERMAN
                • Jun 2009
                • 559
                Thanks for everyone help i found in service mode 5-302 set time had to adjust till i got it to show correctly with it being an older mp2000 you have to set time zones. With newer copier i didn't have to mess with them they adjust for time zones.
                • davel
                  • Oct 2011
                  • 1103
                  That still won't stop it displaying time in 24 hour format.
