aficio 2022
  • Gab
    • Aug 2015
    • 657
    aficio 2022
    Image at the half was ok but at the other half were white areas like waves. I have seen it a lot of times when developer is missing.
    Because customer didn't want to spend lot of money i replaced developer (type 28) and alla gears. Executed 2 802 and 2 802 programs. first it worked fine but next day the same problem . Any idea(except to replace the hole drum unit) ?
  • solorajder
    • Jul 2010
    • 106
    Re: aficio 2022
    Did you cheched if toner is fall in to the developer unit? Maybe stuffy toner unit.?
    Sent from my G8441 using Tapatalk
    • ridgemill
      • Sep 2017
      • 180
      Re: aficio 2022
      A simple replacement of a drum type 1027 should do.
      If the customer is worried about the cost, you can tell them that the average life of the drum is much more than the stated life of 60,000 copies.
      • StephenB
        • Aug 2015
        • 238
        Re: aficio 2022
        Gab, sounds like your toner density went low, this is probably due to not fully removing all the old developer.
        The rear auger chamber is sealed, and requires alot of effort to get all the old dev out. (from experience of faiuled and successful rebuilds)
        If there is to much developer, the density drops. Katun also offers a replacement gear kit !
        Dont waste your time on only developer, do drum, dev, blade and gears.
        If it's a high volume, quality important account...just replace the drum unit. Don't loose a client over this minor repair
        • luca72
          • Oct 2017
          • 1678
          Re: aficio 2022
          try cleaning the mirrors of the laser polygon engine
          • Mark Bbb
            • Jun 2012
            • 1662
            Re: aficio 2022
            It's the paper.
            The paper it is.
            Xerox or IBM businnes paper (cheapest paper of the 2)
            Which paper do they use?
            OR
            You have put a 3030 F.U. in
            • keithxxiii
              Just a tech
              • Nov 2014
              • 468
              Re: aficio 2022
              Could it be the magnetic roller? I had this problem from a MP4000 machine. Prints patterns of waves when you do an almost full coverage print.
              Aye! Cut the crap
                • 36855
                Re: aficio 2022
                If the machine is not level front to back, you will get this problem.
                • fshead
                  • 2356
                  Re: aficio 2022
                  do your lungs and customer a favor and blow that machine up..
                  I both loved and hated that stupid drum unit...
                  You can try a new 1027 but they wont last long and that leakamatic will scatter toner on your feed rollers and tray
                  in time..
                  • jonhiker
                    • 661
                    Re: aficio 2022
                    replace the pcu, this model uses the 1027 PCU, i think the number is 411018.. the type 1027 were not meant to be rebuilt in the field, but swapped out as a whole unit. the old unit is then sent to a place that rebuilds them.
                      • 36855
                      Re: aficio 2022
                      in time..
                      If you get a "new" PCU and the product either starts or end with a "R" it is a Rebuilt unit.
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        Re: aficio 2022
                        Forgotten to mention:
                        The front ball bearing of the pressure roller is not at the proper place, due to the green lever wich has been broken (green lever for customer to easily remove jamed paper).
                        Or bad paper !!!
                        • NeoMatrix
                          Senior Tech.
                          • 3514
                          Re: aficio 2022
                          First, I'm leaning towards toner on the slit glass...
                          Second, fuser press roller jumped out of postion ???
                          Scan a sample copy of the fault and post the image to the forum.
                          • davel
                            • Oct 2011
                            • 1079
                            Re: aficio 2022
                            Dev init is 2801, just use 411018.
                            • Mark Bbb
                              • Jun 2012
                              • 1662
                              Re: aficio 2022
                              Originally posted by Mark Bbb
                              It's the paper.
                              The paper it is.
                              OR
                              I haven't made myself clear enough:
                              the PCU (and sometimes hot roller) is contaminated with gasses of cheapest paper. So, you need to
                              1. use better paper (Ricoh is ok)
                              2. replace pcu
                              Never use a 3030 fusing unit in a 2022 or v.v. !!!! Thaht might give the same problems!
