Problem Scan to folder SMB v2
+ More Options
Posts
  • Ales
    • Oct 2013
    • 14
    Hello everyone,
    I have a MPC2004ex it does not scan with SMB2/3, my OS is windows 10.
    I have changed the port number 445 and active SMBv2/SMBv3.
    Another else have this issue?
  • copier tech
    • 8131
    Re: Problem Scan to folder SMB v2
    This topic has been cover soooooooo many times.
    Does it scan OK using SMBv1
    Have you updated the firmware
    etc etc
    โ€‹
    • Ales
      • Oct 2013
      • 14
      etc etc
      I have updated everything (Operating panel,network ecc).
      Windows 10 support scan using SMBv2?
      I have to scan on computers with windows 10 in workgroup not in the domain.
      Thanks for the info
      • keithxxiii
        Just a tech
        • Nov 2014
        • 468
        The usual setback is the antivirus running on the computer. Or the antivirus controlling the firewall.
        I trust that you have configured it correctly and viewed the system log.
        Try the other methods, (browsing the shared folder from the device).
        Configure using TCP/IP (I assume there is no DNS server)
        Aye! Cut the crap
        • Ales
          • Oct 2013
          • 14
          I have disabled the antivirus and port 445 is managed by windows firewall and allows traffic.
          Browsing the shared folder from the device does not work.
          I used static ip and I tried using a crossover cable from pc to multifunction.
          • LNorris
            • Sep 2008
            • 645
            do you have the copier on the domain as well?
            • Ales
              • Oct 2013
              • 14
              I do not work in the domain
                • 37252
                Do you have McAfee security software on the computer? The first time you scan to a computer with McAfee, a security alert will pop up and ask if you want to allow or block. If no one is at the computer, the alert will time out and block by default.
                • keithxxiii
                  Just a tech
                  • Nov 2014
                  • 468
                  How about the network sharing properties? You said it is on a workgroup. If it is connected to a network, it will have different network profiles. (domain, public and work)
                  Maybe one of the settings there is preventing it from getting browsed or connected.
                  BTW, is it wired or wireless?
                  Aye! Cut the crap
                  • guitar9199
                    • Sep 2016
                    • 1099
                    Start simple... Go into your Network adapter Properties, select the IPv4 protocol, click Properties>Advanced>WINS Tab, and change from the default setting "NetBIOS over DHCP" to "NetBIOS over TCP/IP".
                    Check all your "Inbound Rules" in Windows Firewall and make sure all instances of "File and Printer Sharing" and "Network Discovery" are set to "Allow", and THEN try your scan folder.
                    If you have ANY instances of McAfee or other 3rd Party Security on this computer, you might still not be able to get through. McAfee, Norton, Zone Alarm, etc.'s only goal in life is to block what you're trying to do when it comes to scans!! It sees SMB (v1-v2-v3) as a security flaw, and it's trying to protect you from yourself!
                    Good Luck!
