Ricoh MP 5002 SC 533 ?
  • mrfuser
    • 1604
    Manuals says duct fan, anyone know which one usually goes south to cause this error?
    K
  • mrfuser
    • 1604
    Re: Ricoh MP 5002 SC 533 ?
    FYI: front fan under the control panel.
    • davel
      • Oct 2011
      • 1089
      Now you know which one to replace.
      • mrfuser
        • 1604
        Really? Which one 🤪😂
          • 37047
          Try under the scanner glass. Try searching the parts catalog for duct.
          • keithxxiii
            Just a tech
            • Nov 2014
            • 468
            Hi there,
            Had this problem once. It is the cooling fan when you remove the square-like cover in front. Just below the operation panel. One screw when you open the duplex/right side cover.
            Aye! Cut the crap
            • mrfuser
              • 1604
              Hi all,
              please notuce i figured it out above above and let everyone know which fan for future reference .
              Hope someone one else can use the info
              • mikadonovan
                • May 2008
                • 2931
                I believe it was once referred to as a scirocco fan. Used to fail on the B230/B222 series and cause the IH coil to blow.
                NEVER ASSUME ANYTHING
