Ricoh MP 6002 DF
  • craigo
    • Nov 2016
    • 11
    Ricoh MP 6002 DF
    DF jams only in scan mode. Intermittantly on the first page scan. Feeds in and secondary rollers do not start but PF and SEP rollers do. Leaving a crunched trail edge of the first document.
    I replaced both RADF Feed Motors and ran about 66 test scans and worked. 2 days later they called back same problem. Both Motors were off a used machine. Any ideas.
    Craig
  • tufbnme
    • 493
    Re: Ricoh MP 6002 DF
    ADF jams 6002.pdf
    • Lagonda
      • Aug 2008
      • 1649
      Originally posted by tufbnme
      [ATTACH]40893[/ATTACH]
      At last Ricoh recognise that there is a problem with the DF on these models Shame that they are about 3 years too late as most of the range has be retired from our fleet.
      I'm not sure oil and/or replacement of the nominated parts is the answer as I did all of that with no noted success.
      • StephenB
        • Aug 2015
        • 239
        I have run into a broken "plastic loop" on the Lower paper feed guide ( look closely at the upper diagram, right beside #8) there is a plastic loop to secure the guide. It breaks easily.
        It's difficult to see, but you will have a bit of play in the guide.
        My repair, I drill 2 small holes and use wire to make a loop to secure the guide. Works perfect, no failures yet.
        • NeoMatrix
          Senior Tech.
          • 3513
          While ago now...
          Had a MP"C" 5000-1 have scan motor driver IC/Triac fail(over heat) on the scanner circuit board.
          I remember the ADF running random jambs and smelling of over heating. I removed the ADF cover in an attempt to find the fault.
          I run a heap of test scans when "BAAAANG" the driver chip exploded with pieces of IC embedded in the foam ceiling of the office.
          It was both a blessing and a curse; the fault was no longer dynamic, but the driver board took a few days to arrive from the supplier.
          The newer models may have address the issue of motor driver IC overheating with better heat sinking ???
          • davel
            • Oct 2011
            • 1095
            I believe you are thinking about the RADF on MP 5002.
            • StephenB
              • Aug 2015
              • 239
              Yes, you're right....sorry
