Mpc305 WIth Various Problems
  • printertnc
    • Jun 2015
    • 68
    Good evening
    I have an MPC305 with various problems
    The printer gave this flaw
    See image attached
    - On some sheets came out an abnormal fold
    - If you printed in color, it printed an out-of-color strip
    I changed:
    FUSER
    PAPER TRANSFER -D1176201 (D118-6204)
    PCDU BLUE
    For a month everything worked ok, but after a month there was a problem with color and creases
    I'm going crazy, help me
    20181017-181641 — imgbb.com20181017-182655 — imgbb.com
    20181017-182709 — imgbb.com
  • JDYAL
    • Sep 2008
    • 187
    Re: Mpc305 WIth Various Problems
    The wrinkle in the paper is probably a bad fuser unit. The fusers in this model suck. The pressure roller starts to deform causing the problem.
    • printertnc
      • Jun 2015
      • 68
      Thanks for your answer.
      The fuser is brand new as it is possible that still continues to make wrinkles? And then it does not always.
      Is it my impression or is the model mpc305 a model with many faults?
      • copier tech
        • 8172
        Originally posted by printertnc
        Good evening
        See image attached
        I changed:
        FUSER
        PCDU BLUE
        What firmware versions is the machine on? there were loads of FW issues early on in production om this model.
        • JDYAL
          • Sep 2008
          • 187
          How many prints on the machine? I've had 5 of these machines and I didn't like them at all. My customers ran them into the ground fast. I no longer have the machines.
          • printertnc
            • Jun 2015
            • 68
            Firmware installed:
            Nome modulo Versione Part number
            System/Copy 4.10 D1175437A
            Network Support 12.34 D1175430N
            Font EXP 1.00 D1275800
            PS3 Font 1.11 D6415763A
            PCL Font 1.13 D6415758A
            Fax 09.00.00 D1175424L
            RemoteFax 04.00.00 D1175425F
            NetworkDocBox 2.02 D1175431F
            Web Support 1.12 D1175427K
            Web Uapl 1.10 D1175428G
            Scanner 02.02 D1175426H
            animation 1.00 D1175429A
            Printer 1.11 D1175432L
            PDF 1.04 D1175436D
            RPCS 3.12.24 D1175433D
            PCL 1.12 D1175434H
            PS3 1.00 D1175435A
            Data Erase Onb 1.03m D3775913
            GWFCU3.5-5(WW) 08.00.00 D6495570K
            PowerSaving Sys F.12 D1175423C
            Engine 1.54:02 D1185775E
            OpePanel 1.22 D1171491M
            LANG0 1.22 D1171491M
            LANG1 1.22 D1171491M
            BLACK AND WHITE - 2565
            COLOR - 1803
            The color problem with that strip how could I solve it?
            The PCDU has been changed 2 weeks ago
            • JDYAL
              • Sep 2008
              • 187
              There is definitely newer firmware for this machine.
              • davel
                • Oct 2011
                • 1107
                Clean laser shield glass for white line.
                • JDYAL
                  • Sep 2008
                  • 187
                  I was gonna mention that but I could remember where the lasers were. They are above the drums, under the paper exit cover. Not easy to get to,but definitely worth a shot to clean them.
                  • copier tech
                    • 8172
                    Firmware installed:
                    PDF 1.04 D1175436D
                    PCL 1.12 D1175434H
                    PS3 1.00 D1175435A
                    COLOR - 1803
                    At first glance I know the system/copy firmware is on 4.13 now.
                    These 305's always suffer from the white line/deletion issue, mostly happens on low use machines, like yours is.
                    There was a bulletin about this, if I can find it I will attach.
                    • printertnc
                      • Jun 2015
                      • 68
                      Why did the problem occur a month after changing the PCDU as suggested by Ricoh technical support?
                      The strange thing is that if I print the test pattern - checker flag pattern with black e yellow I do not have any white lines
                      However I try to follow your advice.
                      Thanks for now
                      • copier tech
                        • 8172
                        Thanks for now
                        The issue is with your cyan (blue) PCDU.
                        I trust you are using genuine Ricoh toner?
                        • Zeldaman
                          • Mar 2011
                          • 946
                          Hi there!
                          Is the ptr the modified one or the original part? The old one is very good in jamming & wrinkling when getting old. The white line in cyan is not the lasershield, there is crap under the dr-blade.
                          As the other tech say update the complete fw.
                          Greetings...
                          • francisco
                            • Nov 2009
                            • 168
                            Good evening
                            See image attached
                            I changed:
                            FUSER
                            PCDU BLUE
                            The wrinkle in the paper is probably the transfer roller
                            you must open cyan unit ,and clean developer unit.
                            • emiliorsg
                              • Jul 2018
                              • 141
                              Me too. I have had several machines of this model and I have been changing them. I still have some in some client and it's a problem.
