Ricoh mp c5503
  • heath03
    • Jul 2018
    • 80
    Ricoh mp c5503
    changed the pcu (2x) to make sure
    itb and cleaning blade
    still streak in the same spot
  • JDYAL
    • Sep 2008
    • 186
    Re: Ricoh mp c5503
    What about the itb cleaning unit? How does that look?
    • FrohnB
      • Jul 2017
      • 1919
      Re: Ricoh mp c5503
      Changed the Black PCU twice? And by "itb and cleaning blade", do you mean you also replaced those? Have you checked the fuser? Transfer Roller? I Have had a label wrap around the PTR and cause a line like this. What's the color of the line? In the photo it just looks black/grey, which would point me to K PCDU or Fuser, but if it's a brownish color, then I would suspect ITB cleaning unit.
      Omertà
      • emiliorsg
        • Jul 2018
        • 141
        Re: Ricoh mp c5503
        it seems from the itb cleaning unit or an adhesive on the itb surface.
        • granata
          • Jan 2012
          • 32
          Re: Ricoh mp c5503
          maybe a lump of toner on the black development group, did you check?
          • davel
            • Oct 2011
            • 1077
            Re: Ricoh mp c5503
            Just yesterday I had 20mm wide streak on yellow on a 2503, turned out to be a buildup on the dev roller, worth checking.
            • heath03
              • Jul 2018
              • 80
              Re: Ricoh mp c5503
              ty guys,
              pulled out developer unit. was a huge build up on it. i thank you for the help!!
