MP C6502 SC672-11
  • MitchD
    • Oct 2012
    • 164
    MP C6502 SC672-11
    Thanks for any help you can provide.
    "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
  • guitar9199
    • Sep 2016
    • 1100
    Re: MP C6502 SC672-11
    This MAY be a shot in the dark, but what I would try is replacing the HDD, reflashing the firmware, and as a last resort REPLACE the harness from control panel to Main controller. You may have a bad connection somewhere in between.
    ...good luck. Those are definitely "Head Scratchers"!
    • JDYAL
      • Sep 2008
      • 187
      x2 on the HDD had this happen recently, same 672-11
      • copier tech
        • 8221
        Firmware is always the first thing to try before replacing any parts.
        ALL firmware files not just a few.
        • MitchD
          • Oct 2012
          • 164
          UPDATE:
          Replaced the HDD's and both cables from OP panel to the IPU. Also tried another OP panel and made sure all firmware was current.
          Still can not get the hard keys to work on the op panel. And still the issue of 672-11 if I do not unplug and discharge the machine.
          I truly am lost on this one
          • LNorris
            • Sep 2008
            • 645
            I know its not the same model, but i fought a old 7500 with this 672, it was the adf wiring harness shorting out, disconnected it and it came up. took me a week to find it.
            • semi
              • Sep 2008
              • 195
              Try disconnecting the paper feed board,boot up with covers open,see if that works
              • keithxxiii
                Just a tech
                • Nov 2014
                • 471
                I know how it feels... recently had an mpc 3004 on the same problem. It turned out to be the HDD. Luckily, we give out SSDs to techs on the field to replace whenever the HDD fails.
                Aye! Cut the crap
                • MIKON
                  • Jul 2015
                  • 191
                  Try cleaning the dimm memory chip' contacts
                  • MitchD
                    • Oct 2012
                    • 164
                    UPDATE:
                    I have tried all suggestions listed above with no luck. I ordered and installed brand new HDD's from Ricoh (ouch$$) with no change. We are pulling and replacing the machine. Customer has been understanding thus far, but its starting to wear thin.
                    I will continue to troubleshoot the machine in the shop and hopefully update this thread with a solution.
                    • adoug
                      • 23
                      Does the device have a fax installed?if so check and make sure the jumper is turned on,
                      Also check powersaver firmware level
                      • ctuinstra
                        • Apr 2011
                        • 49
                        And there we are, at the end and yet again, no solution.
                        • joserf
                          • Feb 2019
                          • 24
                          [QUOTE=MitchD;708791] Estoy abierto a cualquier sugerencia Gracias por cualquier ayuda que pueda proporcionar. [/COTIZAR]
                          I have had that problem for a long time, the machine boot has lost it in the flash memory. The only way is to forcefully insert the firmware. I don't have the program to do it. Changing the controller for a good one should work for you
                            • 37628
                            Yes, there you are. Another asshole grave robber.
                              • 37628
                              [QUOTE=joserf;2217239]
                              I would advise you check the date that a thread was first started. Just because someone else digs it out of the grave does not mean that you need to reply. Otherwise you are going to collect a lot of red cards.
