MP 6503 noise
  • Bozz
    • Oct 2014
    • 16
    MP 6503 noise
    Hey i have a MP 6503 that makes a big clunk noise. Customer uses lock printing and says it happens when a print job is sent to the printer but not while it is printing. Usually its just in rest mode and receiving the data in, not even waking up to print it and making this noise. Video attached the printer is not in rest mode but still makes the noise when receiving data.
    I had the controller box swung out and couldn't see anything moving whilst in was in rest mode and receiving the data. Would the drum or dev turn while in rest mode receiving data but not printing? I pulled the drum and dev out and could not find any issue.
    I thought it may trigger the fuser to warm up even though its not going to print but turning the rollers and nothing feels off, i didn't take the fuser out was running short of time.
    Also thought it could be the draws lifting if in sleep and receiving data but i emptied and loaded all the draws no noise.
    Does not happen at all during a print run.
    Thanks for your ideas.
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: MP 6503 noise
    Output mode is your friend.....my friend.
    Have you tried turning stuff on and off in output mode?
    • copier tech
      • 8237
      Re: MP 6503 noise
      This model does make a single clunk sound if being send a job from sleep.
      I think its the draw lock mechanism, but this is normal.
      I cant open your video.
      • Bozz
        • Oct 2014
        • 16
        Re: MP 6503 noise
        Thanks for the reply. Can you view it now?
        • Bozz
          • Oct 2014
          • 16
          Re: MP 6503 noise
          Tried everything in there i could think to try. Maybe i was missing something with a clutch or something. Can you see the video?
            • 37652
            Re: MP 6503 noise
            I believe that to reduce flat spots on the pressure roller, this model has has pressure release mechanism that moves the pressure roller away from the hot roller when the machine sets idle.
            • davel
              • Oct 2011
              • 1109
              Re: MP 6503 noise
              Draw lock is on MPC, MP6503 is the SOP update to MP6002.
