Ricoh MPC3502
  • davez@copysystemspa.com
    • Feb 2018
    • 26
    [CQ] Ricoh MPC3502
    Greetings, I have posted before and have a Ricoh MPC3502 that is losing color quality on the printing end only. Color copies on the same machine are fine. When you do a color calibration test pattern for both copying and printing, the copy color calibration test pattern is perfect. However, the printing color calibration test patterns are light right in the middle of the pattern. See sample attached. We have tried everything to fix this issue; firmware updates, PCU units, belts etc to no avail. We can correct the issue temporarily by doing a factory reset. Just wondering if anyone has an idea of what this might be and a better fix other than the factory reset.
  • saz_ryd
    • Jul 2008
    • 26
    Re: Ricoh MPC3502
    Clean Laser Unit
      Re: Ricoh MPC3502
      Originally posted by saz_ryd
      Clean Laser Unit
      but he said copies are fine.
        Re: Ricoh MPC3502
        do nt do factory reset WITHOUT having the birth cert ( should be under panel in front door ) the after reset you will have to enter SM and re-input all the mis.match values
          • 37414
          Re: Ricoh MPC3502
          You're thinking of main memory clear, SP 5801-001 clear all or SP 5801-002 engine clear.
          • tufbnme
            • 493
            Re: Ricoh MPC3502
            Is the paper running the same direction when printing as copying? Can you upload the sample of the copying too? Show the lead edge.
            • adoug
              • 23
              Re: Ricoh MPC3502
              Reset the printer application in sp mode, 5-801-8 I think,
              Then try a colour printout
              • DougD
                2020 Retired
                • Sep 2016
                • 76
                Re: Ricoh MPC3502
                Gut feeling?
                Replace the mirror motor before you proceed.
                The motor is cheap compared to your time spent sleepless staring at the ceiling when you're not on the company clock.
                  • Feb 2018
                  • 26
                  Re: Ricoh MPC3502
                  Hey guys, original poster here. To answer your questions and for additional information on the issue:
                  1) Yes, the paper is going through the same way for copies and prints.
                  2) We do a full memory clear in SP801 which includes the sub 8 Printer application. The problem is temporarily corrected but returns in a couple of weeks.
                  3) The mirror motor replacement seems odd as color copies are perfect. The issue is only with color printing.
                  Any other thoughts?
                  • fshead
                    • 2375
                    Re: Ricoh MPC3502
                    I will add this that if you pull the laser unit to clean and ck mirrors etc you must wipe the inside cavity top too.
                    I just did two dirty lease returns and there was a good amount of dirt above where laser unit sits
                    • adoug
                      • 23
                      Re: Ricoh MPC3502
                      When you reset your full memory clear do you do the ACC again??
                        • 37414
                        Re: Ricoh MPC3502
                        When you reset your full memory clear, i.e. SP 5801-001 or SP 58001-002, and you do not have the machine's birth certificate in hand it will require a lot more than ACC. If you don't know what you are doing it could take at least 2 hours to manually adjust to where forced line position will not error out.
                        • adoug
                          • 23
                          Re: Ricoh MPC3502
                          Hi mate see attached,hope this helps
                          • anhdangvui
                            • Jun 2013
                            • 4
                            Re: Ricoh MPC3502
                            I am also experiencing this problem
                              • Feb 2018
                              • 26
                              Re: Ricoh MPC3502
                              A Doug,
                              Thank you for the service bulletin, That is exactly what we were looking for. We will give it a try.
