MPC 3002 swapping out all boards
  • fshead
    • 2376
    Hi
    I have 2 mpc 3002 which I must merge the parts to make one.
    The 1st is low meter 80k but all the internal metal has "pitted" and there
    iare issues where the wonderful warehouse "techs" walked allover the top of machine and warped the
    top frame,smashed the control panel...
    The other is high vol.400k and clean and complete.
    If I swap the whole controller boxes do i still need to address different serial numbers?
    I will print out both smc sheets and will re calibrate dev units and laser if needed.
    AM I missing anything here?
  • AMS
    • Jun 2017
    • 73
    Re: MPC 3002 swapping out all boards
    the controller board and bcu serial numbers have to match. Different hard drives will give you address error so you will have to format it. You can change serial number in the factory mode.
    • rbwright
      • Oct 2018
      • 11
      400k is nothing. the machine will ask for the sn it wants, and it will recognize a hdd swap and format. make sure to replace dv units for blank lines.
        • 37444
        Just make sure you use the serial number that is on the serial number label on the back of the machine.
        • DougD
          2020 Retired
          • Sep 2016
          • 76
          Hell no. Print the counter page from each machine to get the true serial number.
          • fshead
            • 2376
            i just fired up the 2nd unit and its 600k,but 50k color.
            i know about the factory mode.
            i always do a hdd full format,and have plenty of spare low vol developer/drums at the stand by if needed..
            • DougD
              2020 Retired
              • Sep 2016
              • 76
              I would highly recommend that you enter SP mode on both machines before you start swapping boards and print 5-990-001 on both machines first and then do 5-801-003 all the way to the last one and then 5-832-001 and lastly Facsimile Ram clear Factory.
              It's not like the old days when there was a barcode on the scanner stay that you could swap to make it work.
              The new machines need matching Eprom & NVRAM data and I can see a future with SOP where board swapping will be prohibited.
              • copier tech
                • 8136
                Hi
                What is the issue with the higher count model "clean & complete" why the need to swap boards?
                • DougD
                  2020 Retired
                  • Sep 2016
                  • 76
                  When I worked for a Sharp dealer in the 1990's we figured out a way to zap the total counter back to zero so the sales department could feed there family selling crap.
                  • fshead
                    • 2376
                    All i am doing is making two into one..
                    a 60k meter unit into a 600k unit..
                    The parts that matter will reflect real meter so why not?
                    • FrohnB
                      • Jul 2017
                      • 1919
                      If it's just the Scanner frames and Op panel on the low meter unit that are messed up, and the high meter is fine, I would just swap all the PCDU'S/ Transfer unit/ Fuser over to the high meter machine, and make a note on a history sheet that you put units with 80k in that machine, and then next time you replace a part, reset the count for that unit, I see absolutely NO need in this situation to swap controller and BCU. But if You're gung-ho on doing it, then all I can suggest is BICU and Controller as a set, then swap the back covers between the two.
                      Omertà
                      • fshead
                        • 2376
                        thanks.
                        Half the people ask about meters and most never even check once they get the machine.
                        This is going to be a quick sell it,set it and forget it till
                        something fails.
                        I just think i cover any issues if the machine shows 60k vs 600k........
                        I gotta gut one of these anyway so might as well..
                        • copier tech
                          • 8136
