Connecting ad-hoc Ricoh MPC2503SP issue
  • MatthewS
    • Nov 2012
    • 36
    Hi All,
    I have an issue connecting and printing to the Ricoh mpc2503 from my pc. I have installed IEEE 802.11a/g/n Interface Unit Type M2 on Ricoh and set MPC2503 to ad-hoc mode with no security key setup. However Connecting and printing from iPhone is no problem. When I try connecting to Ricoh from my pc its says 'cant connect to this network' even though its broadcasting. I'm lead to believe that connecting and printing from pc ad-hoc method should work. My OS is windows 10 pro.
  • jonhiker
    • 661
    Re: Connecting ad-hoc Ricoh MPC2503SP issue
    the Ricoh will need to be configured manually to connect to your wireless network. It will need the ssid, password, etc. You may also need to change the channel, the default for the Ricoh wireless is 11. Your router may be on a different channel.
    I have done plenty of these, most of our guys hate doing the wireless installs...
    • MatthewS
      • Nov 2012
      • 36
      hi jonhiker,
      In this instance im not connecting to router. I only want to directly connect my pc to the Ricoh (as the host) not through wifi network if that makes sense.
      • keithxxiii
        Just a tech
        • Nov 2014
        • 471
        Depending on your region, you have to select the ad-hoc channel from user tools, and from the SP 5840-006 and 007 respectively.
        Aye! Cut the crap
        • NeoMatrix
          Senior Tech.
          • 3513
          Are you referring to something like AirPrint ?
          Airprint sets up its own isolated network address range. You will need to find what network address/subnet range the AirPrint is using.
          Some network examples might be.
          Eg. 10.1.1.1
          Eg. 10.1.2.1
          Eg. 192.168.1.1
          Eg. 192.168.2.1
          Use Ping.exe to play around those ranges or use other network identifier software.
          • dudeman
            • Feb 2019
            • 7
            make sure your machine is not trying to use IPv6, as updates are causing this to be first protocol. You can go into properties and turn it off and see if it connects (it will then default to v4). Try to ping it; look at the channel its broadcasting over as well as if its using WEP or other, look at those
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Originally posted by MatthewS
              hi jonhiker,
              I think you mean connecting via an ethernet cable directly to your PC?
              Depending on the age of your pc it should just be a matter of setting the copier to an address within range of your pc.
              You might have to use a crossover cable depending on the age of your pc.
              • copier tech
                • 8237
                Hi All,
                If you want to connect just one pc to the copier is it close enough to simply run a LAN cable or even USB?
                If not get the wifi to connect to the same wifi your pc is on.
                • davel
                  • Oct 2011
                  • 1109
                  Why do you need to use ad-hoc, does the customer not have a wireless router. Never used ad-hoc myself, make sure PC and device are on static IP and channels match.
