cant find the hard drive info on my parts manual???
  • fshead
    • 2376
    hi
    I am looking to find out they type and size hard drive for a possible machine to purchase.
    I looked thru all the electrical and accessory pages in my parts manual and saw no hard drive listed..
    Is this somewhere new?
    Or what type and size HDD needed on these
    thnaks
  • mikadonovan
    • May 2008
    • 2931
    Re: cant find the hard drive info on my parts manual???
    A model number would help. I looked at the c5502 PC and the HDD is listed on the controller page. If your machine does not have it listed there , it may have been an option (and an old machine).
    NEVER ASSUME ANYTHING
    • copier tech
      • 8138
      HDD size on copiers is irrelevant really, you can however simply fit a larger one.
      Why is HDD size important to you?
        • 37447
        Have you tried looking at the manufacturer's label on the drive itself?
        • CopyBats
          • Aug 2011
          • 145
          Originally posted by fshead
          hi
          thnaks
          You'll probably find it in the product support guide version for that machine model
          If it works, don't touch it.
          • guitar9199
            • Sep 2016
            • 1100
            Browse the Hytec dealer services website, key in your make/model, and you can find the actual part number there.... and buy a hard drive from them if you like. Sometimes they have really good sales.
            • davel
              • Oct 2011
              • 1099
              • fshead
                • 2376
                im sorry my bad..
                trying to do too many things at once
                it is the mpc 3003...
                • fshead
                  • 2376
                  looking at the brochure it says 250 gig must be laptop size sata drive but
                  I see there are different types of SATA drives sata1 sata2 and sata3,does it matter?
                  and regarding hytec i never found them cheap and i use to send boards on minolta and sharps over 20 years ago..
                  good company but pricey..
                  • guitar9199
                    • Sep 2016
                    • 1100
                    D1425765
                    • NeoMatrix
                      Senior Tech.
                      • 3513
                      If the HDD is still working plug the HDD into any PC computer SATA slot.
                      How to get HDD size information:
                      From the windows CMD prompt type in :
                      wmic diskdrive list brief <enter>
                      Alternatively you could use:
                      diskpart <enter>
                      list disk <enter>
                      How to clean/wipe a corrupt HDD. (WARNING : Use at your own risk)
                      diskpart <enter>
                      list disk <enter>
                      select disk "your volume number here" <enter>
                      clean all <enter>
                      **** """CLEAN ALL""" will write zero's to every track on the HDD *****
                      • bat
                        • Sep 2008
                        • 140
                        I belive this is the part you looking for.D146_D147_EXP_V2.18 199.pdf
                        • DRichard
                          • May 2008
                          • 482
                          You are so right. THAT is why our agreements stipulate that our techs are the ones to remove the HDDs and then hand them over to the concerned parties. We can then replace the drives as we need to.
                          "Enjoy every sandwich."
                          -- Warren Zevon
                            • 37447
                            I believe that is also Ricoh's published policy.
                            • keithxxiii
                              Just a tech
                              • Nov 2014
                              • 468
                              Just got the SSD 250GB Laptop HDD from amazon. I will try with the 03 series if it works well.
                              Aye! Cut the crap
